Can you hear anything when you pull the handle out from the car
*UPDATE* Apparently there IS a manual release....buried at the base of the door... but requires tools to access it!This is a recurring safety issue as in the event of an accident the rear seat occupants cannot get out.
Another design flaw, as tesla didn't bother to fit a manual mechanical release lever to enable egress.
Check out the issue here....
Very useful to know exactly where it is in an emergency. Note to self, keep a screwdriver inside the car!*UPDATE* Apparently there IS a manual release....buried at the base of the door... but requires tools to access it!
In the event of an emergency no way would anyone trapped in the rear of the car get out (child possibly), or anyone get it open from outside to aid rescue. I would not risk putting my child in the rear that's for sure.
Crazy!
This is what I was thinking, removing the cover, and then putting the rubber mat over it again. This is all of course if TM3 has it - will have a look over the later/ weekendI wonder if permanently removing the flap is an option, possibly with an extra loop to get to the chord? If its the same on the Model 3, then the removeable insert is going to act as a cover/deterrent for the release.
That's not good. A flawed design that has not even considered the safety of occupants in the rear in the event of an emergency.Just had a quick look in mine. Drivers side at least has no hidden panel under the rubber mat as per that YouTube vid. So without major disassembly doesn’t appear to be any way to open the rear door unless you have power.
If you have kids in the back of any car you absolutely would enable a child lock to stop them falling out, in most vehicles this is mechanical, so it wouldn't operate the door in the case of a crash whether the (redundant) power was available or not.I certainly wouldn't want children of mine in the rear.
