Can’t be tire bc I replaced with a new oneor bead leak or small puncture in the tread.
If tire has been replaced, it’s either valve or wheel. Did they put new valve on? If so it’s probably wheel. Any you didn’t specify which model you have. Check the For Sale section.Can’t be tire bc I replaced with a new one
2021 Y LR with InductionIf tire has been replaced, it’s either valve or wheel. Did they put new valve on? If so it’s probably wheel. Any you didn’t specify which model you have. Check the For Sale section.
Interesting, as that could certainly be the culprit.No they didn’t put new valve I don’t think
Only suggestion would be to remove the cap and listen for a leak...Anyway to test a valve leak at home?
The easy button method is get a spray bottle, fill it fully of soapy water, and spray everywhere on the wheel and tire area. If it is leaking, it will produce baby bubbles.Anyway to test a valve leak at home?
Tire issues are NOT covered by the Tesla warranty. I'm not sure why many people think that is the case. It's no different from any other OEM. And unless you could prove that a wheel crack was due to a manufacturing defect, I think you're SOL there as well.I also am noticing (on my MYLR received last month !) that one tire (left rear) goes low fairly quickly whereas the others seem to hold air very well. Not sure what to do. Local nearby tire shop would probably check it out for $10-20, worth that not to drive to Tesla dealer (40 min each way). And I can imagine dealer saying tire issues aren't covered by warranty. I'll check the valve. I think not having a good seal on the tire bead is a common cause, but less likely on new rims. Wonder what luck with warranty if the rim is cracked ?
