goneskiian
Ugh. These inside wear reports are disappointing, but having read quite a few reports on the S too, not entirely surprising. Guess I'd better have the alignment checked as a preventive measure!
Looking at the tire spec on TireRack for those, they are considered summer tires. The tread wear rating is only 220, which is pretty low compared to comparable all-season tires. Yes, your wear is very uneven, but regardless those tires are pretty soft to begin with.I too recently discovered (and not pleased) that due to the negative camber on the rear alignment the tires wear out on the inside edge faster than normal. I have a P90D Model X with 16k miles on the odometer in 9 months since new (with moderate to conservative driving, and yes, some occasional fast launch mode acceleration). I have Michelin 275/45R20 110Y Latitude Sport 3 tires and they have been properly inflated since delivery. Since the front tires are a different size (255/45R20 105Y), I can't rotate them. The tire manufacture documentation states that these tires are only rated for 20,000 miles. I'm going in for an annual service appointment early next week and will probably have an alignment job done. I'm also noting that the automatic lowering setting can cause premature tire wear. Mine was set to go low at speeds above 50 mph. Last summer we took a trip from WA to NE and back - about 4200 miles. Today I changed it to only lower at speeds above 80 mph to see if this helps with the next set of rear tires. Thanks for the info and discussion on this topic.View attachment 212104 View attachment 212105
.Has anyone done any comparison tests to quantify energy usage (wH/mi) differences between the various X suspension settings?During our orientation to the car, the sales associate told me he always kept his in "very low" and recommended I do the same to get better energy efficiency due to the improved aerodynamics.
I think @Roamer may have when he first got his X last winter..Has anyone done any comparison tests to quantify energy usage (wH/mi) differences between the various X suspension settings?
Same here with 10,000 miles on 20" Conti-silents, auto lowering set to 50mph (which is probably 25% of my mileage). Even tread wear inside to outside of all four tires.I've had no such problems with my 20" Conti-silents. Almost 15,000 miles and 7/32 left on all 4 with even tread wear. I have auto lowering set to 50 mph.
I'm curious for anyone who's had to replace tires did you follow up with an alignment and if so was it off at all? Wondering if this is pure camber or a combination of the two seeing that we have a mixture of folks with different wear levels with relatively common auto adjustment.
My S I always drive on low and have 22k miles in 13 months and the tires look perfect. I may have the 19" wheels less prone to inner wear but I can't see any difference.
Just had our annual at 16,000 miles. One of the items they had to do was replace one tire that had a nail/screw in it, in location that could not be fixed. They recommended that I replace all the tires at $375 each...
-Measured tire tread depth at:
(Outer) (Center) (Inner)
LF: 4/32 6/32 2/32
RF: 4/32 6/32 2/32
LR: 8/32 8/32 8/32 (New)
RR: 5/32 6/32 3/32
Wow! I was so shocked that I declined, as I wanted to research this a bit. Felt that 16k is just too few miles to be putting new tires on... And ours is only a 60D (for what it's worth).
This is so not what I expected. Anyone hear of any improvements to this (I've read about keeping the suspension on High) or other, better wearing tires or ??? I cannot imagine spending $2,000 per year for tires! There has to be a better answer...
Did they do an alignment too? It's part of the annual service. I just had mine done a bit ago and found the rear toe was out of spec (negative on both sides). This setting when combined with the rear camber is a particularly bad combo when it comes to tire wear.Just had our annual at 16,000 miles. One of the items they had to do was replace one tire that had a nail/screw in it, in location that could not be fixed. They recommended that I replace all the tires at $375 each...
LF: 4/32 6/32 2/32
RF: 4/32 6/32 2/32
RR: 5/32 6/32 3/32
