Yep same feet. Three placed the same way.Did you also put a rubber feet? If so, what size? TIA
Good luck! You have to pull the upper trim piece harder than you’d expect but the clips are solid and you won’t break it. It’ll come off cleanly then snap back after.Thank you
Got it. Thanks again!Good luck! You have to pull the upper trim piece harder than you’d expect but the clips are solid and you won’t break it. It’ll come off cleanly then snap back after.
This worked for me. I just pulled down the bottom edge of the camera housing slightly per the YouTube video and put one clear bumper in each corner. No need for three as far as I can tell ... there is nothing in the center that would rattle or vibrate against something else if those two feet are in place. Then I pushed to snap the housing back into place.Yep same feet. Three placed the same way. View attachment 970278
Before I mess with my rear view mirror housing, was the rattle was like a sliding/shifting sound? Only happens on rapid accel/decel or bumps in road. Like something shifting or sliding inside of housing unit. Thx.Yup. Intermittent based on road surface and speed not consistent and a little push on the housing usually silenced it temporarily. Been just tolerating it but then I saw this genius screen spline fix. I used a sturdy plastic spoon from an MRE and gently pried the front of the housing away from the windshield enough to insert the rubber spline and worked it in one side to the other. Took less than a minute. Happy now to report no more rattles.
I would not describe mine that way. Bumps or acceleration were not related. Certain rough road surfaces and the right speed set up a sympathetic frequency vibration in the mirror housing. BTW, the screen spline fix is still working.Only happens on rapid accel/decel or bumps in road. Like something shifting or sliding inside of housing unit. Thx.
That's not what mine sounded like.Before I mess with my rear view mirror housing, was the rattle was like a sliding/shifting sound? Only happens on rapid accel/decel or bumps in road. Like something shifting or sliding inside of housing unit. Thx.
thanks.I would not describe mine that way. Bumps or acceleration were not related. Certain rough road surfaces and the right speed set up a sympathetic frequency vibration in the mirror housing. BTW, the screen spline fix is still working.
