Rebooting the computer
Discussion in 'Roadster 2008-2012' started by supersnoop, Feb 25, 2016.
Tags:
  1. supersnoop
    supersnoop Tesla Roadster #334
    Pflugerville
    Any tips for restarting the internal computer? I had a log transfer interrupted, and now I get a "memory stick failure" every time I try to pull the logs. Any tips?
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Try opening and closing the charge port door rapidly for something like 5-8 times.
  3. ElectricLove
    ElectricLove Member
    If this doesn't work, message me and I'll give you a more elaborate method of resetting the entire thing... But hopefully this works!
  4. Panicopticon
    Panicopticon Member
    Syracuse, NY, USA
    #4 Panicopticon, Feb 25, 2016
    Assuming it's a 2.0 you can pull fuse #13 and the aux battery fuse (listed as a 30A?), or disconnect the aux battery. It's possible just waiting for the car to sleep is sufficient, but I doubt it. This is a guess from the wiring diagrams, sadly there are a number of other fuses that are associated with the VMS, but I believe they're all for switched actuators (trunk, locks, etc).
    Another possibility is to carefully unplug one of the connectors from the VMS module in the passenger foot well, see this for more.
  5. wiztecy
    wiztecy Active Member
    This is what Tesla does and what I do whenever the knickers get into a hissy with the USB stick:
    How and where to pull plug / power to the VDS?
    Just be VERY careful with the connector plug, its brittle and needs to be correctly and gently pulled or else it'll break.
  6. supersnoop
    Pflugerville
    There is not a it of room down there, but pulling the plugs on the VMS did the trick!
  7. wiztecy
    You can drop the VMS box if you need more room....
  8. tvuolo
    tvuolo Supporting Member
    Colorado
    I just had to do this again and I always forget how little space there is in there to work. Sheesh that's tight, and I'm not a big guy!
    I was having the USB issue. I popped it in while it was charging and it started the transfer as soon as the charge was done, but never stopped. 90 minutes later I just pulled the USB drive to see if I could get it to start over. No luck... just errors.
