I'm rebuilding my second Tesla Model S; if you're interested in my first rebuild experience,
see here. This is a 2017 (December build) 75D with 4k miles.
So the first thing I did after moving the car into the garage was replace the pyrofuse and connect the cut loop. I gave the battery a jump although eventually the dcdc fully charged the 12v battery and the car was operating on its own power. Off to a good start.
Unfortunately though, what comes next is not as glamorous...
I decided to put the car in drive to back out of my driveway and then back-in again. That was fine. Although next, I decided to see if the car chargers, so I connected the HPWC and the car began charging! However, after 5-10 minutes the car stopped charging and I noticed the charge port was red.
I then made the unfortunate discovery the car was extremely low on coolant. So I decided not to touch anything until I installed a new radiator and added G-48 coolant. This is mistake #1.
In the meantime however, I noticed an update from Tesla, so I decided to perform the update. This is mistake #2. Evidently, you should never perform an update on your car if it's still undergoing repairs and all ECU interfacing components are not connected. I suppose this seems obvious in retrospect, but nevertheless something to always keep-in-mind. So, naturally, the software update failed. Although, the update seemed to have flashed some components, but not all. So, I started seeing this error:
Well, this sucks. The car will not drive anymore. In addition, the contactors are not closing and the dcdc is not charging the 12v anymore. Also, asking Tesla to send me an OTA will not work since the car is salvaged. So, I had to rely on my software engineer background and help from some members to gain access to the car and derive a bit more information, but first, I tried the update again from factory/developer mode:
Here are the
syslogs.
Some notable references from the logs:
gwmon 10261: BMS contactor close request
gwmon 15444: timeout - BMS contactors did not close, ctr state OPEN (0)
gwmon DCDC NOT present, NOT updateable (NO bootId, NO versionMsg, NOT enabled), BMS contactors NOT closed
gwmon chgph1: no hwid
As you can tell, the BMS, DCDC, and Charger are not responding, which contributed to the upgrade failure. Here is a list of diagnostic errors I'm seeing:
It seemed suspicious the on-board charger was MIA, so I figured there could be a blown fuse. Will expand on this in the next post.
