Regenerative braking disabled in very cold conditions
Discussion in 'Model S: Driving Dynamics' started by tennisman, Jan 16, 2015.
  1. tennisman
    tennisman Member
    Westfield New Jersey
    Has anybody experienced the following message upon starting up their car - "regenerative braking malfunction a proceed with caution"? I could tell when I let off the accelerator, I could feel car did not slow down as usual. Should I contact service center?
  2. santana338
    santana338 Member
    Manchester, NH
    Definitely contact the service center. They likely know about it already. They will let you know how they plan to address the problem.
  3. pgiralt
    pgiralt Supporting Member
    Cary, NC
    Did it actually have the word "malfunction" or did it say "disabled"? I think there are some legitimate conditions that disable regen (very cold weather) but the message wouldn't use the word "malfunction" if it was intentional.
  4. Aussie Bob
    Aussie Bob Member
    Ottawa, Ontario canada
    We have that problem in cold weather until cars heated up. Was temperature a problem?
  5. tennisman
    tennisman Member
    You're right - I think it actually did say disabled. My car is always in the garage, but for a couple of days it was outside - the temp at night was down to about 10 degrees F - could this have caused it? And will it reset itself or does it have to go to service center to do this?
  6. EdA
    EdA Model S P-2540
    Massachusetts
    When the battery heats up enough regen will start coming back.
    You can get around this issue by keeping your car plugged in and before you leave preheat the car
    raise the charging limit a bit. 15 minutes of this should get you a decent amount of regen.
  7. tennisman
    tennisman Member
    Thanks to all for your help - great to know that Tesla owners are so helpful!!
  8. NigelM
    NigelM Recovering Member
    Sarasota, FL
    Mod note: thread title amended for clarity. There was no malfunction, this is normal operation.
  9. EdA
    EdA Model S P-2540
    Massachusetts
  10. santana338
    santana338 Member
    Manchester, NH
    Ooops. Should have questioned the wording first. Glad it all worked out.
  11. islandbayy
    islandbayy Active Member
    Greendale, Wisconsin
    I didn't see it mentioned, so I will say it now.
    The reason the Regen gets disabled, is due to the battery temp. A Lithium Ion cell, such as what is in the Model S, cannot be charged when the cell temp is at or below 32*F (Or in other words, freezing).
    The reason for this is when charged below freezing, the internals of the battery Electroplate themselves. The end result, is PERMANENT IRREVERSIBLE Capacity loss. Once the pack heater and/or driving the vehicle bring the cells internal temp above 32*F, charging will resume. The amount of regen will increase as the cells reach the ideal temps.
  12. RichardC
    RichardC Cdn Sig & Solar Supporter
    Toronto, Canada
    Now going through my third Canadian winter with the Model S. In order to avoid (or substantially reduce) this problem, I set the car to charge for five or six hours immediately prior to driving, and also turn on the interior heating for 10 minutes before leaving, all of which results in greater comfort, better regen function and reduced battery power consumption.
  13. Rheazombi
    Rheazombi Member
    Boston
    I get this problem daily, as I always have to park outside (19 degree weather here at the moment). Usually takes half an hour of driving to get my regen back. You're not alone, OP!
  14. bint2k
    bint2k Member
    Toronto, ON
    Hey RichardC, what other issues have u come across if not charged before driving in the winter? IE. length of time for the cabin to heat up if left out in the cold?
  15. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    It was mentioned above but tying to time charging to finish right before you leave and turning on your heat remotely with the app 30 min before you leave helps.
  16. rapoport3a
    rapoport3a Member
    Ontario
    Those things do help, but if you have time of use pricing on electricity, you may be spending more $$ than you planned. Where I am, at 7 AM in the winter the price goes up about 50%. I'll warm up the battery after that but I try like anything not to charge it then. I do a few calculations to try to stop the charging just before 7 if I'm leaving by about 8.
    If I leave later than that, I may as well charge the battery the night before. The morning charging isn't foolproof, either. Last week I set the timer to start charging at 5:15 AM but the car refused to start charging. First time that's ever happened; no explanation. If I had charged the battery while I was awake, I would have seen the problem and done something about it. (The solution was to reboot the touch screen.)
  17. Rheazombi
    Rheazombi Member
    Boston
    Haha aww, if only I had home charging ;) I could certainly start the heater through the app though (we've been doing that anyway, but we usually only know we're going to drive somewhere about 5 min before)
  18. invisik
    invisik Supporting Member
    Minneapolis
    Please note, when regen is disabled or limited, the car will not slow down as much as it normally would when you lift off the accelerator. This always surprises me a little at the first few stops. You will have to press the brake to slow.
    Stay warm!!
    -m
  19. tliving
    tliving Member
    New England, USA
    Daily occurrence to see it disabled here in New England. Mostly driving around these days with it disabled or very limited and thats with a lot of driving. Below about 30F you'll see it a lot.
