I don’t believe a premium connectivity subscription is required to leverage a MyQ subscription.Is MyQ included with the monthly data subscription? (premium connectivity).
Premium Connectivity is neither required to use MyQ nor is MyQ included with Premium Connectivity.I don’t believe a premium connectivity subscription is required to leverage a MyQ subscription.
Sounds complicated—like some raspberry pie BS. No offense! Am I incorrect?Forget myQ subscriptions. If you have a myQ garage door opener and other smarthome devices like bulbs, do some research and install home assistant on a spare laptop to run a home automation server. You can then link your Tesla and myQ garage door to the home assistant and make it open the garage door automatically when your phone or Tesla enters a geofenced location. Additionally you can automatically turn on and off your lights in your home or set your thermostat to away mode.
Only complicated if you have no experience with computers. There are plenty of guides and you can install the self contained HAOS on the raspi or spare laptop to handle a lot of the complexity.Sounds complicated—like some raspberry pie BS. No offense! Am I incorrect?
HmmmmOnly complicated if you have no experience with computers. There are plenty of guides and you can install the self contained HAOS on the raspi or spare laptop to handle a lot of the complexity.
In my opinion it's worth the complication since all my smart home devices work with home assistant and I don't have to mess with Google home, homekit, Alexa and a bunch of other smart home apps, everything just works with home assistant so I have one point of access. Since it's all managed by me, I don't have to worry about some cloud service going out of business or pay subscription fees for things as simple as opening my garage door from my car.
That's the big advantage of a home assistant system. You keep full control over your data. You can still integrate devices from other smart home ecosystems into your home assistant setup, but if you want a fully locally controlled system you can integrate zwave/ZigBee switches/lights into your home assistant easily and setup scenes, and automations through home assistant instead of through a cloud enabled app. All the logic and location tracking happens locally on your home assistant server and you can make it externally accessible by opening a port for it on your router and using a service like duckDNS to give it a URL. Home assistant already has a login page so you can secure things if you make your instant accessible externally.Hmmmm
So—curious…with this system, who’s always listening?
e.g. Alexa is always listening; so is “Hey, Siri” and “Apple Home”; as is “Hey, Google”.
This is the entire reason I refuse to get a home automation system. I’ll settle with having Siri listening when I tell it to listen (when I push the button)—thank you very much!
Okay—now you’ve motivated me to learn how to do this. Sounds like a PC would be needed to use as a server, rather than MacOS or iOS, yeah???That's the big advantage of a home assistant system. You keep full control over your data. You can still integrate devices from other smart home ecosystems into your home assistant setup, but if you want a fully locally controlled system you can integrate zwave/ZigBee switches/lights into your home assistant easily and setup scenes, and automations through home assistant instead of through a cloud enabled app. All the logic and location tracking happens locally on your home assistant server and you can make it externally accessible by opening a port for it on your router and using a service like duckDNS to give it a URL. Home assistant already has a login page so you can secure things if you make your instant accessible externally.
I have my instance accessible from outside my home network and I have integrated a whole lot of smart home ecosystems into my home assistant like Nest, zwave, myQ, kasa, Tesla, wiz. And there are a whole lot of others you can add. It's a real rabbit hole once you get started but it's definitely the best move if you want to setup a smarthome that you have full control over.
You can still keep everything connected to WiFi. For cases like myQ they will still need to be connected to the Internet as the Home assistant integration talks with the myQ API to send and receive commands. I run two WiFi routers in my setup, I have my main router which all my computers and secure devices connect to, and then I have a secondary router hooked up to the main router and all my smart home devices are assigned to that router and my home assistant server runs on that router. I do this Incase there is a security breach with any of the smart home devices (since they still talk to their respective APIs other than zwave/ZigBee). This allows my secure network talk down to my home assistant network and it allows me to forward external access requests to the secondary router which then forwards it to my home assistant server. Reduces the possibility of anyone from the outside being able to have access to my secure computers. It's probably overkill, but I like the piece of mind especially when you have something externally accessible.Okay—now you’ve motivated me to learn how to do this. Sounds like a PC would be needed to use as a server, rather than MacOS or iOS, yeah???
I’m guessing it’s not possible to connect any of those smart devices (nest; MyQ; etc.) to WiFi in order to make this work, correct? Meaning, me using this to have local control does not preclude Google from capturing my nest data or preclude Chamberlain from capturing my MyQ data, correct? Or, are you saying that this method involves me creating a local WiFi network that is NOT connected to the internet? (Sort of like when setting up a TESLA Wall Connector, yeah???)
Thanks!You can still keep everything connected to WiFi. For cases like myQ they will still need to be connected to the Internet as the Home assistant integration talks with the myQ API to send and receive commands. I run two WiFi routers in my setup, I have my main router which all my computers and secure devices connect to, and then I have a secondary router hooked up to the main router and all my smart home devices are assigned to that router and my home assistant server runs on that router. I do this Incase there is a security breach with any of the smart home devices (since they still talk to their respective APIs other than zwave/ZigBee). This allows my secure network talk down to my home assistant network and it allows me to forward external access requests to the secondary router which then forwards it to my home assistant server. Reduces the possibility of anyone from the outside being able to have access to my secure computers. It's probably overkill, but I like the piece of mind especially when you have something externally accessible.
There are some devices that can be completely controlled locally like ZigBee, zwave, TP-Link kasa and some tuya devices. Home assistant let's you aggregate everything into one easy to access, control and secure panel.
You will need a raspberry pi or a spare computer to run the home assistant server, it runs on Linux. You can installed the Home Assistant Operating System (HAOS) on any spare computer and it will handle most the complication.
See that link to see what all you can do with it, they have a demo on their site.Home Assistant
Open source home automation that puts local control and privacy first. Powered by a worldwide community of tinkerers and DIY enthusiasts. Perfect to run on a Raspberry Pi or a local server.www.home-assistant.io
The installation instructions are below:
20 years ago I would have been all over this. Now I’m spoiled and just want it to work without having to manage on-prem infrastructure.Forget myQ subscriptions. If you have a myQ garage door opener and other smarthome devices like bulbs, do some research and install home assistant on a spare laptop to run a home automation server. You can then link your Tesla and myQ garage door to the home assistant and make it open the garage door automatically when your phone or Tesla enters a geofenced location. Additionally you can automatically turn on and off your lights in your home or set your thermostat to away mode.
Yeah it's a tradeoff between managing your infrastructure or paying for a service and having it harvest your data.20 years ago I would have been all over this. Now I’m spoiled and just want it to work without having to manage on-prem infrastructure.
Many routers now have the ability to manage dynamic dns for you. One less thing to worry about.Yeah it's a tradeoff between managing your infrastructure or paying for a service and having it harvest your data.
Though, there isn't much to manage, I never really have to touch my home assistant instance, mostly just have to update my DuckDns IP whenever my ISP is doing maintenance and I get assigned a new public IP.
Yeah, just mine doesn't work with DuckDns. Duckdns is completely free unlike some other dynamic dns providers.Many routers now have the ability to manage dynamic dns for you. One less thing to worry about.
Very hard to find dns services for free these days. I think NoIp is still free for 1 domain name and is compatible with many of the major consumer grade router brands.Yeah, just mine doesn't work with DuckDns. Duckdns is completely free unlike some other dynamic dns providers.
I did use that for a while but they require you to login to their site every few weeks and "verify" that you are still actively using it which makes it useless for me.Very hard to find dns services for free these days. I think NoIp is still free for 1 domain name and is compatible with many of the major consumer grade router brands.
Oh wow that sucks. Especially since determining dns activity can easily be done by themI did use that for a while but they require you to login to their site every few weeks and "verify" that you are still actively using it which makes it useless for me.
