Roadster Foundry License Plate Bracket
Discussion in 'Tesla Parts for Sale' started by Palpatine, Sep 27, 2009.
  1. Palpatine
    Palpatine Banned
    Seattle
    #1 Palpatine, Sep 27, 2009
    http://www.evcomponents.com/ProductDetails.asp?ProductCode=RFLPB
    Finally! A non-invasive solution for mounting your front license plate without having to drill holes and destroy the look of your Tesla Roadster. This lightweight steel license plate bracket mounts into the existing hole in the center of the Roadster's grille making it much less invasive. It is also easy to remove if you want no plate for special occasions or photo opportunities.
    Designed by Tesla Roadster owner Stephen Casner and made available through EV Components.
  2. Palpatine
    Palpatine Banned
    Seattle
    If there is enough interest, we already have a design ready to machine for a European license plate. I could have that ready in three weeks.
    Click on the contact button on our website to let me know.
  3. vfx
    vfx Well-Known Member
    CA CA
    #3 vfx, Sep 28, 2009
    Mine early Steve model sits in a box waiting for the day that will never come when I get a fixit ticket for no front plate.
    I have to ask why they aren't black by now.
  4. Tdave
    Tdave Member
    Owings Mills, MD
    I lasted 6 weeks. Got my ticket on Friday. Plate is now on.
  5. Palpatine
    Palpatine Banned
    Seattle
    I am at two months and five days with no ticket for the missing front plate.
    In fact, I had a discussion with a police officer in a parking lot as he admired my Roadster. I pointed out the missing plate and he said that they would only ticket me on it if I am pulled over for something else. It is one of those secondary items. Not a primary ticket offense.
  6. vfx
    CA CA
    To stay?
  7. Palpatine
    Palpatine Banned
    Seattle
    Why would it matter if the license plate is covering it?
  8. SByer
    SByer '08 #383
    Cupertino, CA
    I was bugged by this until I got it on the car. It's always in shadow, mostly hidden. I had thought about getting mine coated black, but I've decided it's simply not worth it.
  9. Palpatine
    Palpatine Banned
    Seattle
    Now I understand.
    I will look into getting them another color when they arrive.
    I have 25 being machined right now.
  10. Roger Reid
    Roger Reid Old but effective
    Caldwell Idaho
    I will be powdercoating mine black when it arrives.
  11. Roger Reid
    Caldwell Idaho
  12. pgwoosley
    pgwoosley Member
    Installing EV Comp. Lic. Plate Bracket
    Here are a few hints on installing the EV Components license plate holder/bracket that attaches to the tow hook hole.
    The bolt you need to purchase to make the attachment is 10 mm diameter and 1.5 mm pitch. I happened to have purchased one 30 mm long, but it does not need to be that long. Try to purchase a bolt with a head other than a hex. The one I bought has a 17 mm hex head and needed some washers to get a firm grip down in the base of the V where the holder attaches to the tow hole. A bolt with an Allen, Philips, or other head probably would fit easier.
    Install the holder to the car before you install the plate to the holder. Particularly if you use a hex-headed bolt a socket extension with a U-joint would be useful, but a regular extension will work if you push it in the socket hole only part way.
    The screws that came with the standard front license plate fit the new holder/bracket. They take a small Allen wrench.
    It might be a good idea to carry sufficient tools in the car to remove the plate and bracket if the tow hook is ever needed on the road.
    The new holder looks great.
  13. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    I am expecting a 2010 Roadster shortly. Can anyone show my how the front license plate is normally attached, if you don't use this gadget?
  14. Palpatine
    Palpatine Banned
    Seattle
    I still have about 20 of these Tesla Roadster license plate kits in stock.
    They are not yet on our new website, but they are still available.
    $85 each.
    Thanks,
    James Morrison
  15. Bradleybang
    Bradleybang Member
    Oakland, CA
  16. SByer
    SByer '08 #383
    Cupertino, CA
    #16 SByer, Apr 13, 2010
    Normally two holes are drilled through the front bumper. I wasn't about to let that happen to mine. Get the foundry bracket- at the rally the cars with the bracket definitely looked better than the drilled ones. And the bracket is easily removed for shows or pictures if you want.
    Sent from my Nexus One using Tapatalk
    Here's another picture w/ CF frame:
  17. Doug_G
    Ottawa, Canada
    ICK!!!! The standard mount looks HORRIBLE.
    I think I'll be ordering one of those brackets, then.
    James - are you going to put those back on your webstore, or should I call?
    Thanks,
    Doug
  18. Bradleybang
    Bradleybang Member
    Oakland, CA
    Remember to tell Tesla to not install mount. In California, where required, you must request not to have installed and sign waiver. Not sure of O'Canada's requirement.
    Foundry install is pretty easy and does look good with a frame.
  19. Doug_G
    Ottawa, Canada
    For Canada (and probably elsewhere) when your car is about to ship, Tesla sends you an email asking for all kinds of information. Among other things they ask you to opt in/out for the license plate bracket.
    I've already ordered the bracket from James' company, and I opted out.
  20. samcarney
    samcarney Sam C
    Great Lakes, Sonoran Desert
    James is the EV Component License Bracket still available. I made it for one full year without the front plate. You have a new customer now complements of the Chicago PD.
