nexsuperne101
Closed
He becomes Kryton?
That might be lost on any TV viewers not alive in the UK in the 90's
He becomes Kryton?
I miss those marathons! Big RD fan here, thanks to PBS/KCTS-9 Seattle which we get here on cable.As others have said Red Dwarf was popular here in the US on PBS. I volunteered at the local PBS station in Seattle when doing their fundraising drives a few times. One time they were running a RD marathon...
It's a little bit above my knowledge but as far as I can tell we are at the point that all smaller ICE's should easily be bested by Li-Ion powered motors. We are very nearly there with cars and anything smaller than a car should be a blow out since the small additional price is easily compensated by the convenience.
The Mahindra E2O. I don't think this would be available in the USA. We can't have the Renault Twizy either.
Leaf is a 80 kW motor and 24 kWh or 30 kWh pack
Mhindra E2O is a 20 kW motor and 15 kWh pack. The think that surprised me most was the pack is running at 48V instead of the higher 300+ volts you see on most EVs.
The pack is big enough (assuming no heat degradation) but the motor is too small.
Does it have a cooling loop or a fan duct for the battery pack? If not it'll depreciate like a Nissan Leaf.
If they actually did cooling for the pack it might actually have better range than a Leaf in the long run.
Note if it doesn't have the Chademo port it also doesn't have Air Conditioning so to have what I'd consider a normal US car features you have to get the highest trim level.
An update on the ongoing boondoggle:He said something about not one Carbon Capture and Storage facility has ever been built on a coal power plant. That's not true. There was one built, paid for by the Government of Saskatchewan.
It cost us C$1.5 billion, and rising (approximately 808 million Pounds). It doesn't work.
It doesn't sequester the carbon it's supposed to, and emissions at the plant have actually gone up.
What it does is take the carbon, and turn it into the slurry. That slurry is then contracted to be sold to an oil company to inject into marginal oil wells to increase the pressure so they can pump more oil out of them. However, since the CCS facility isn't sequestering the carbon it's supposed to, we're not delivering the product, so we're paying contractual penalties to the oil company. So it's costing us, the taxpayers, more and more every day.
In SK the power company is a Crown Corporation, owned by the government, so what it does everybody in the province pays for.
It's a complete boondoggle, all because our current government wanted a talking point to point to say they were green, while at the same time cutting environmental programs.
The fallout from SaskPower’s Boundary Dam CCS debacle
A Carbon-Capture Debacle in Saskatchewan Raises Questions About a Technology That Isn’t Living Up to the Hype
Technology to Make Clean Energy From Coal Is Stumbling in Practice
Wait. A 48V pack and CHAdeMO?!?
Isn't CHAdeMO limited to 100 amp at pack voltage? (Getting the 50kW label from 500V.)
A 48 V car would seem to be limited to about 5 kW on 'DCFC'.
