@Papafox your post about free rolling is pure gold, thank you. Do you use any technical indicators to decide whether the stock is in a downward or upward trend that makes you more confident in executing these transactions? I've tried it in the recent downturn (but I bought the later-dated option first because I thought the share price would turn around, enable me to sell the earlier-dated option) -- but of course that didn't work out.
Just for the sake of clarity, "neutral" cash-wise but not delta-wise, correct? you'll lose some delta on the way (granted should not be much for those super DITM positions).
I'm in a similar position (but my calls are more ITM). I've done the following process:
- Decide if I want to maintain the exposure via options or not, or if I want to decrease or increase my exposure via options. My answer to generally maintaining exposure was yes (because I believe the current market situation is temporary), but that I do not want to invest more money in options, i.e., I have to check what rolls I can get based on the current value of my "options portfolio".
- I've made a spreadsheet in which I'm analyzing how many options I can buy with later expirations at different strikes based on the value of my options portfolio, and how that would change my delta exposure relatively. I.e., I'm using "portfolio delta", the delta of all the options I want to roll, as a base.
- I've decided what the maximum portfolio delta reduction I'd be willing to accept would be, and defined that at >= -25%.
- I've decided about the moneyness I want the new option to be, and defined that the strike should be <= $300
- Since most of the options I've shortlisted have a lower delta than my current position (i.e., they moves slower than my current position), and because I believe we're close to a local bottom, I'm right now waiting for an up day to roll.
Here's a screenshot of my spreadsheet:
You can see, e.g., in row 17, that a roll to a $225 Sep 23 call would decrease my portfolio delta by 18%, and the gamma by 33%. So this position will move much slower -- however, I might accept this as a "haircut" for trying to time the market with options and failing at it. Given that options have generated overproportionally more gains for me in the past than it now takes rolling them, I might accept this as cost of doing business. Especially because I believe that options will continue to generate overproportionally more profit than straight stock in TSLA.
Row #19: I could also go for a $275 Sep 23 call which initially will move a little bit slower than my current position, but because gamma is higher, it will move faster once the share price appreciates significantly.
Looking forward to feedback and thoughts around this process!
