Perfect solution for Ka-52s ......Something else the brits have done (in addition to some drone help)
A thread by Trent Telenko on mines and de-mining:
Thread by @TrentTelenko on Thread Reader App
@TrentTelenko: This is going to be a thread about the Ukrainian counter offensive and some snarky comments about Ukraine 'making excuses like the Nazis' for the counteroffensive being slow due to vegetation. I'll su...…threadreaderapp.com
Are you incinerating that fire will set off mines???!???…Another solution is going to be to just herbicide and burn all the fields which should set off most of them. Right now the fields are green- roundup and burn should remove most of them.
Thx for posting.missile issues
Thread by @MaxRTucker on Thread Reader App
@MaxRTucker: I spoke to a Lt. Colonel in Ukraine’s air defence command, who revealed several new facts. First, Kyiv was on the brink of evacuation in Dec due to the intensity of Russian strikes on energy...…threadreaderapp.com
But if they did a low level (very low) DoD guy they never got a seat in the pentagon wouldn't be someone that would know about it. I have never seen someone post so authoritatively on so many topics which were completely outside their area of expertise as Trent. Then he tries to pick fights and posts as if the world disagreed with him. Entertaining at times but not something to repost IMO.
Edited- especially as trent ignores the key points here. It is anti-tank mines that are really slowing things. In the trenches they are not coming across so many anti personnel mines. Many of the antipersonnel mines were laid by Ukriane to slow Russia in the Kharkiv area.
There have been some mixed mine fields but mostly the anti-vehicle fields are just that. It is too bad we don't have something similar to TOS russia system but I'd think Ukraine could develop one after the war. Another solution is going to be to just herbicide and burn all the fields which should set off most of them. Right now the fields are green- roundup and burn should remove most of them.
I’m pretty sure Roundup-ing otherwise active agricultural fields with Glyphosate herbicide won’t leave enough flammable residue to make much fire; indeed, I was unaware that burning the fields would set off the mines(?).
missile issues
Thx for posting.
Ukr has received substantial aid but it unfortunately has often been too late.
West leadership dithering is the core reason why the offensive is stalling (Ru should not have had the time to lay down those extensive minefields plus more advanced aircraft should already have been provisioned).
Tree lines are the best option until a good solution is found for clearing the fields, it is worth trying to find a good solution.The Ukrainians are moving along the tree lines which can't have hidden underground mines. If the dirt was disturbed there, it would be obvious. Putting mines in agricultural fields is easy because how do you tell between a tilled field and a mined field?
Yes fires will set off mine fuses. In fact Ukraine frequently set forest fires along the Russian border in Kharkiv to allow the raiders to safely cross. Doesn’t take a lot of heat. Russian telegram channels would warn border guard that forest fires meant crossing attempts. Once the field gets dry (October) but before it snows a grass fire will set them off easily. Grass fires are hot! - as a forester that does quite a bit of burning for forests management this is something I know about (fires not mines). If an understory forest fires do the trick a grass fire would do wonders and they are fast, any wind and they can move! the issue is you need dry grass! Low humidity and dry grass…. Game on.Are you incinerating that fire will set off mines???!???
Pulling out of the grain deal where Ukraine voluntarily blockaded itself has been a disaster for Russia. The tables have been turned. Ukraine is not blockaded but Russia is. There are many other videos about Russia's problems in the Black Sea now including this one from Jake Broe:
