FalconNinetyD
The locking pin *will* bend if you press the release button on the adapter while sliding the adapter onto on. Make sure you only press the button when removing an adapter.
After all, the split phase U.S. residential power system is to blame here. High power applications require high currents. Even with everything hard wired in the HPWC, there were troubles like blowing 100A fuses and super hot handles.
The European UMC delivers 11kW with 16A current. This is because it is 3 phase power. Still, the UMC adapter snaps on and requires very little force to do so. I usually charge with 12A at home and use 16A only for quick daytime top ups.
My electrician recommended to re-torque the screws in my wiring on a regular basis. This is a scaring thought when I consider the mass adoption of electric vehicles. Someone will charge his EV at home or in a hotel with a degraded electrical infrastructure.
Yep, and not hard to do. Given how many occurrences of melted plugs there have been out there, I'm surprised that EVSE manufacturers are putting these into both the wall plug and car plug.RE: system design -- I would think there's a way to integrate one or more thermistors into the J1772 signalling circuitry, so that if the temperature on/near either the adapter contacts or the plug blades gets too hot, the car stops charging...
Question: Is residential power typically three-phase in Europe? We have plenty of three-phase here in N. America but it is not typical in residential settings.
FlasherZ or others with long experience in the electrical world: could you explain why it is that a standard circuit breaker remains unaffected by the situation apparent here? Why is this not the case of "runaway" current, so to speak?
BTW, our experience and subsequent discussion with one of its employees has the Tesla showroom at Fashion Square in Scottsdale AZ was as follows: its 80A charge site there has its entire length of cable get so hot that the employees wear heat gloves to detach the working end from their cars. Not knowing this, I detached mine barehanded and, while I didn't blister my hand, I will vouch that it was as hot a handle as I could bear. Employee (he was quite junior) told me they are not worried. I would be!
Because you need less current than the max amperage the breakers is made for to heat this cable. A short of a few amps will heat the cable significantly
The adapter is designed to couple the Mobile Connector to the electrical socket. Cabling should have low resistance and therefore little heating effect at the design current. The problem with the adapter arises when it is not well connected, resulting in high contact resistance and therefore, excessive heating. The total current draw through the breaker is normal, so it does not trip. Tesla should really put a thermistor in the adapter coupler to shut down or reduce the charging current. This thermal protection would protect the MC from damage from poorly connected sockets and loose adapters. The socket can melt too if the screws holding the wire to the back of the socket are not torqued properly. That melting can also damage the MC plug at the same time.FlasherZ or others with long experience in the electrical world: could you explain why it is that a standard circuit breaker remains unaffected by the situation apparent here? Why is this not the case of "runaway" current, so to speak?
Got it...I think. Let me write this through and let me know if I'm understanding this correctly:
Let's say I have a motor that demands a lot of current - say 1500W at 120V. If I wire it with, say, 22ga cord then in two shakes of a coon's tail that cord's wires are gong to be saying "Holy Crapoly, we're passing on far too many electrons!"....and heat up with all that excitement and, eventually, melting from it.
That meltdown will cause a short circuit...and THAT is what will trip the 20A breaker further upstream.
OK, so back to our 14-50: in this situation we have gotten 2/3s or so down the prior-described road....a too-thin stretch that shows itself to the world as hot-to-handle...but not, at least so far, to go that extra step into real meltdown. And that "too-thin", as I understand you are saying it, is a function of the poor connection, loose screws or SOME OTHER seeming design fault (OP avers he did have the adapters fully engaged).
About right?
Btw, I can tell from that photo that the adapter is not firmly locked into the UMC , and that is exactly why this melted.
Going back to this comment, I noticed something yesterday: My UMC was replaced a couple of weeks ago due to connectivity with the car issues. Yesterday, I had to charge offsite at 120 volts and changed the adapter. On my "new" UMC, there is about 1/8 to 1/4 inch of "play" between the adapter and the cable with the adapter clicked into place. It wiggles significantly with both the 120 volt and the 14-50 240 volt plugs attached. My previous UMC's plugs were very snug when locked in place.
I've always felt that the Tesla Mobile Connector was a little fragile to use as the primary means to charge a Model S on a daily basis. A Leviton EVB40 (the one recommended for the RAV4 EV that also uses a single Tesla on-board charger) would do the same job as the MC and would be much more durable. Of course, Clipper Creek is the gold standard, but at $1,999 for the TS-60, it is significantly more expensive than both the Leviton and a Tesla HPWC.UMC = universal MOBILE adapter.
This is lightweight unit to carry in trunk and use outdoors or in a parking garage. If it indeed has UL/CSA approval I'm guessing it is as a MOBILE device to be used outdoors, etc. It has a minimal reed-switch type Contactor, not a heavy duty 'clunking' type Contactor. Also it has the different adapter heads with surprisingly minimal connectors lacking the spring-loaded snap-together 'feel good' action we have come to expect from modern devices. A fine (undercoat) cat/dog hair could easily get caught in these adapter interfaces and raise the resistance (ohms) causing heat. Best to leave in trunk for occasional use.
Get a real EVSE from the likes of Clipper Creek to permanently mount on garage wall. Get a CLUNKER!!
How so? The cable and car connector seem to be very similar to Tesla's permanent mount HPWC.
My biggest concern from an engineering perspective is the pin design in the adapters. They seem to be a bit undersized and leave zero room for flex or contact impairments. If the pins were 6 gauge, or perhaps even 8 gauge, they might provide a bit more protection against heat.
