First make sure you are not running any apps that talk to your Tesla, except the Tesla app, these are often the problem when you see times changing. Now then:
- Schedule charge tells the car what time you want to START charging. If you plug in your car within about 6-hours of this time the car will not start charging until the time you have set. So you definitely do not want to set this at the end of off-peak since you will start charging during peak!
- Schedule Departure is something else. On the Schedule Departure page you have two options that are totally independent:
- If you turn on the "Precondition" option, then the departure time above has meaning, otherwise it does not. If, for example, you want your car battery and cabin temperatures to be ready for a 6 am departure, set the time in the departure window to 6 am and your car will be ready for you at 6 am. You can enable this function for all week or just on weekdays.
- If you enable "Off-peak charge" you will see new options below. This is terribly named!!! If you turn this on and set a time in the "Off-Peak End Time" window below, the car will will then automatically start charging at a time so the car reaches the desired SOC at the time you have set (actually about 15-minutes prior.). You can enable this function for all week or just on weekdays. Note that when you plug in the car it will charge for a breif period to determine the available charge rate.
You can pick Schedule Charge or Schedule Departure, but not both.
Most people who have TOU plans use scheduled departure.
