This week’s learning confirmation on short Iron Condors:
1) Don’t bother opening until Wednesday (2DTE). I have ICs that have been rolled out to protect/save one side or the other. Decay is more rapid for the OTM +side, than the -side, because of the distance from ATM. Overall value decay really only happens in the expiration week, and a small bit in the week before. Farther out dates (>2wk) just sit there and the smaller decay doesn’t improve value to the seller.
2) Monday/Tuesday is a bit too volatile to set an IC (yes, if good and/or lucky one might time setting the BPS and BCS sides for more premium, but that’s just not my style
3) Don’t expect to be able to easily close the winning side on Friday, then roll the losing side. This is a method that I have used in the past to eliminate the need for double margin/backing. Unfortunately, today I’m not able to get the -190c/+200c side to close, even at bid (only $0.01) because so it’s far away and no trading volume. It’s worse for non-integer strikes -192.50c/+202.50c, chosen as a roll to avoid previously traded strikes.
3) Finally, unless you want to babysit to the close, keep the short legs at least $10 away from Friday close. I have -p175s which are still in play and refuse to decay. I’m sure the SP will close just slightly below $180, probably above $177.50, so I’m not worried, but babysitting is boring. As described above, the -c190s decayed to $0.01, but I can’t get them to close. I now have a $0.05 order to close the entire IC, so hopefully it happens before 4pm (don’t want to risk some crazy moves AH).
In other trading, with this week’s profits, bought back another Jan25 -c230 near today’s 178 low. Will wait to resell a shorter duration CC. Yesterday filled out another lot at $177.xx, then immediately sold -c185 at $1.65, so a pseudo buy-write. Will expire today, so plan to write a -c190 on Monday. I’m fairly happy with this week’s results and my cash buffer. Definitely hedging my trades in both directions, short- and longer-terms. I still worry about filling the 1/25/23 $140-$150 gap, so keeping almost all my shares matched with CCs. As always, GLTA.
