So we can see that TSLA is still running below the 50% fib channel line, represented by a solid white line here. Last week it got rejected by the 0.381 line (yellow) before consolidating at the 0.236 line (red). Then on Sunday, Morgan Stanley came out with a surprise upgrade (250 -> 400) and TSLA broke through the yellow line with ease, only to be rejected at the white line. Right now it is still retesting the yellow line, previously resistance now support.
Today is CPI so there was no surprise it would pull back to the yellow line before numbers came out. That's fine. However, now that those numbers are known, TSLA needs to hold this support into the close (267+). If it can do that, then expect another test of 280 soon.
If it cannot hold 267 into the close, then expect it to test 255-257 next week before bouncing. That will be where the red line is, plus the ascending anchored vwap from the 212 low. Also the 50 DMA. I don't see TSLA breaking down from this level but THERE'S ALWAYS A CHANCE. If it breaks down from this level, it will be very bearish for the stock because it means the blue line will be next. And you see that TSLA only touches the blue line at major lows (102, 153, 212). Once it touched this line, it would go on to make new highs before touching it again. If this time it touches this blue line before making new high, expect it to break down from the uptrend and really CORRECT.
This is not gloom and doom. As long as TSLA holds these supports, it can undo all the damage and then some in just a day or two. So both bulls and bears beware.
