I don't know. What is the average weight of a Semi load in Texas? (I doubt they normally gross out at 80k.)What do Semis typically do in Texas?
Aero/speed impacts range much more than weight, but it's a fair point.I don't know. What is the average weight of a Semi load in Texas? (I doubt they normally gross out at 80k.)
Yep. I assume Tesla knows the capabilities of their trucks and the details of their loads/routes and would plan their charging network accordingly. It might not be sufficient for the competition especially if the chargers installed for them are just 350kW CCS.I'm sure it's been thought out with the distances, just thinking about 70-80% charge instead of 100% and then the difference in speed, but I guess they could just limit the max speed and avoid that issue.
80mph is typical in many areas. Seems crazy and unsafe, but its the speed limit and most drivers are hustling to make the delivery.That 500 miles range was with an average speed of 55 mph and a max speed of 65 mph. What do Semis typically do in Texas?
Is Tesla using the Semi to bring in heavy duty equipment, rebuilding and relief supplies to the areas damaged by the Tropical Storm? I think it would be good publicity. to show the Truck doing this.
There's more risk than reward. One could break down, they don't have chargers for the Semi in that area, etc. There's no reason for it.Tesla themselves with the Semis they own. Not the ones Tesla sold to Pepsi.
Looks like Tesla setup/is setting up a second version of the prototype Semi production line, speculated to be more automated
Yes if we can get a Tesla semi it will literally change the economics on tens of thousands of acres of land just in our region. We'd be able to restore degraded forests, stop invasives, and make a $. Right now logistics is a killer and fuel costs are a huge % of that.Here is an example of a purpose built PHEV Semi for the logging industry:
Certainly, no frills in the cab.
For eighteen days, beginning on September 11, the North American Council for Freight Efficiency tracked all of these trucks for information on charging infrastructure, cost of ownership, driving performance, and more. Not every truck in the test was active every day, and it doesn’t appear any of the drivers were going out of their way to set new distance or charging records along the way. Tesla may have won out on this test because its Pepsi drivers were more focused on long-distance distribution, while other manufacturers represented were making more frequent regional stops. For example, the longest mileage day for the Tesla Semi incorporated just five stops, while the Nikola made 13 deliveries and one of the eCascadias did 10.
Do you think the Tesla Semi is built to handle logging roads? Thats a pretty brutal use case and something a truck built for highway use won’t work for.Yes if we can get a Tesla semi it will literally change the economics on tens of thousands of acres of land just in our region. We'd be able to restore degraded forests, stop invasives, and make a $. Right now logistics is a killer and fuel costs are a huge % of that.
