I don't get out until 4. I got bed late last night thanks to the Starship presentation, then woke up early crying because of a bad dream (my mother has chronic lymphoma, but is on medication to control it; in the dream, it was killing her and she had decided on euthanasia
). I managed to sleep again, and by the time I woke up it was well after noon.
Great weather again. Almost perfectly calm (to the point that the grass barely moved), which is weird here even in the summer, let alone in the fall.
I haul some posts past the marker post right before the cliff.
I position a whole bunch of post for pounding, all the way up to the cliff.
Time to pound!
The very first post I work on just won't go in. I try two separate places.
After taking out some small loose rocks, I look in. I expect to find a big rock underneath, but, nothing.
I pull the post out and it's a mess. This is *after* straightening out the end.
My best theory is that it might have been a weak post end, combined with a large piece of gravel, that ruined the end - and then in this gravelly ground, a ruined end just can't penetrate. Normally I'd put aside the post and use it in some marshy ground, but there's no marshy ground for a long time. So I go fetch the saw.
After a while hacking away at it, I get it sharp again. It doesn't look at smooth as the posts normally do, however; I suspect that the tips are "hardened" in some way to help penetrate better. I hope it goes in....
Thankfully it does, and I continue on down the line, post after post. As I start to near the cliff, I notice that now my left hand is just starting to tear open at the same spot. So clearly it's the post pounder that's doing this :Þ I try to avoid contacting that spot with the pounder for the rest of the day.
I try to drive a wooden post in at the cliff, but it doesn't go (I was afraid of that... rocks and bedrock are visible so close to the surface. I take the post out, use the saw to resharpen it, put a metal post in, and hammer it down. Even that takes a lot of work and beds up the top end.
Back to pounding in the posts leading up to it!
