Heat transfer solely through the floor of a cylinder doesn't makeanymuch sense. Were that the case, there would be a slight but demonstrable and deleterious discrepancy of cathodic reaction within such a cell. Are you sure of that?
That said, a thinner cylinder floor also provides for more efficient heat transfer, although the overall d(effect) would be, of course, much diminished.
PS: Never confuse rumor with cold hard fact. The world and especially the internet already is awash with disinformation, misinformation and other treachery.
Actually, the situation with utilities is *extremely* locality-specific. I've been watching this. Some utilities are doing one thing, some are doing another. The ones who were already required to shed all generation capacity have a very different attitude from the ones who still own generation, for example. But even among the ones who still own generation, different utilities are jumping different directions.From everything I've read and has been discussed on this board over the past several years, they can't. They have too much money tied to their plants and wouldn't make profit if they tried.
Tesla’s battery strategy is inspiring new electric vehicle startups, but not legacy automakersUntil I see an opened and analyzed pack, I regard all such 'info' as empty speculation.
Well, some people have an art for the timing. Go you! Do what you're good at!I've made all my gains with short term trading and made zero with long term.
Absolutely not! Why would you even think that's a possibility?prismatic cells vs cylindrical cells may be the answer
The 2170 cells also have the increased capacity due to the additional length, about 16%.Publically available Tesla sources. I need to find time to post all of the details, was planning to do so for some time now, but did not get to it. This information has reliability close to 100%. Elimination of cooling ducts between the rows of cells is what allowed Tesla to stick more cells in the P100D battery pack. The same architecture allowed to increase capacity of PowerWall and PowerPack.
If the heat transfer is better or not depends partially on which layer in the cell produces most of the heat. Also the surface area,of the ends of the cells are much less than the sides. But if it works it's obviously better due to the importance of the pack energy density.I was puzzled by this initially as well, but after a closer look, forced cooling through the bottom makes more sense than through the wall. Cylindrical cell is a rolled sandwich with specific heat conductivity across sandwiched layers likely to be lower than through the bottom.
It is absolutely not an empty speculation.
SureThe 2170 cells also have the increased capacity due to the additional length, about 16%.
Look at it in this way: all of the cells sit on the tray bottom of which is actively cooled, all of the layers in the rolled sandwich of a cell are in contact with the tray (through the bottom of the casing). In case of cooling ducts weaving between the rows of the cells only outer case (wall) of the cell is in contact with actively cooled surface.Are you sure that it's just the bottom? Because given the fact that heat rises using either the top, or both the top and the bottom makes more sense than using only the bottom.
Are the cell walls are made of steel , not aluminum?
No link == empty speculation.
fuzzy picture, not sure of pack size
There is a Yeti, you just do not know where to look.There IS a link, you just do not know where to look. Stay tuned.
Seriously, more hard data, less words.
Was this not also the case for 18650s?
Overcoming my usual resistance to commenting on subjects about which I know nothing, is this Teslarati article relevant?Not sure I understand the question - P100D IS using 18650. All battery packs prior to new architecture used cooling ducts between the rows of battery cells. The new architecture did away with these cooling ducts
