Direction of "down" won't change. During descent the BFR will rotate on the long axis so that engines can fire for re-entry and then landing burn.During about 10 minutes takeoff acceleration passengers could not move, even if they tried. Same when coming down. Direction of 'down' would change during flight.
It will, because during launch "down" will be toward the rocket engines, but most of the force during re-entry will be to the "flat" side for aerodynamic braking. It's only for the last little bit that the BFR "capsule" (is there a better word?) will stand on its tail again.Direction of "down" won't change. During descent the BFR will rotate on the long axis so that engines can fire for re-entry and then landing burn.
It seems to me that it will be a simple matter to instruct passengers in advance that they will have to remain in their seats during the flight and bathrooms will be available in the boarding/disembarkation lounge. And it won't be feasible to serve passengers during the flight, as during the coast phase the ship will have a microgravity environment.
For the longest E2E BFR flights, which will be almost 60 minutes as you note, passengers will have to be capable of being in their seats continuously for likely a bit over 2 hours, for the more common 30 minute flights about 1 1/2 hours. If you can't do that, take a jet for 11-16 hours (that includes the time spent board and disembarking) and enjoy the bathrooms and those tiny seats with no leg room...
Yes, I'm surprised that nobody has said: 'Vomit Comet'
According to former Reduced Gravity Research Program director John Yaniec, anxiety contributes most to passengers' airsickness. The stress on their bodies creates a sense of panic and therefore causes the passenger to vomit. Yaniec gives a rough estimate of passengers, that "one third [become] violently ill, the next third moderately ill, and the final third not at all." Vomiting is referred to as "ill".
The Vomit Comet is such partly because it makes repeated climbs and dives (like flying a sine wave). The BFR/BFS trip will be a simple arc and very stable in comparison.
For the Vomit Comet the numbers were something like
I'm assuming a lower rate of vomiting for BFR/BFS hops but it won't be zero. I suppose barf bags will be a requirement.
While I'd not be surprised if the first flights of the BFR were sub orbital, I'll be amazed if SpaceX does city to city passenger service anytime in the next 10 to 15 years, if ever. While it's easy to say it will be a reliable as an airliner, regulatory agencies like the FAA have very stringent and onerous processes to actually get certification. I can't imagine that SpaceX will go through all that for the BFR when the existence of any market for it is unproven.
Incidentally, for the same reasons, I don't think SpaceX is going to be able to use the BFR for NASA astronauts without an escape system.
I guess there will be an escape system. Passengers will be in (40?) small cabins instead of one large cabin. Why? Perhaps there is 40 escape capsules? (Should be 42, but perhaps Elon has not read that bookIncidentally, for the same reasons, I don't think SpaceX is going to be able to use the BFR for NASA astronauts without an escape system.
The BFS (the second stage which includes the passenger compartment) will incorporate a built in escape system. It will have to. SpaceX has given no indication that they are designing the vehicle with a passenger compartment that can physically separate from the BFS fuel tanks and engine section.I don't think SpaceX is going to be able to use the BFR for NASA astronauts without an escape system.
Agreed. When the BFS leaves for Mars it will do so from LEO. No need for an escape system. At that point, you're committed.Now if you are leaving Mars with BFS there is no escape system for a mars launch. The escape system functionality only applies to Earth.
You may be on to something, so I'll wager that first to go would be UAE/Dubaï to China, is another wealthy Asian country. Forget about Canada, we basically follow the same rules as the US.This is also how I'm thinking about point to point passenger service.
However, your comment got me thinking about enterprising governments, and the opportunity that regulatory sticks-in-the-mud might create for competitive countries. Can't fly into the US via rocket because the FAA is such a pain - what about landing in Canada, the Bahamas, Cuba, or Mexico instead, and then doing a short plane ride from there?
And of course, if you're Mexico and you can attract a rocket landing pad (maybe to a point near San Diego), then you've got a shot at more than the the short haul transportation service - maybe those businesses staging through can be persuaded to setup shop right there instead of going over the border (it's the idea, not the specific location that matters).
Part of what got me thinking about this idea of governments competing on regulations, is the behavior I've been seeing around autonomous driving. I was expecting major regulatory oversight, restriction, and friction. What I've been seeing so far are different jurisdictions figuring out how to be more welcoming than the last, and create opportunities to run things in the wild.
It's far too premature for any similar competition around BFR passenger service, but once we have a flying rocket ship that is fully reusable with pinpoint control doing initial satellite launch missions, then we might just see some competition like this arising.
... Forget about Canada, we basically follow the same rules as the US.
