I'm not sure what all this has to do with drag coefficient and it's been discussed to death in other threads. The proper concern trolling for this thread is to ask what this means for battery size? The Model X has Cd of 0.25. How does the frontal area compare to the Cybertruck? Even with a Cd of 0.30, which seems unlikely without major changes, the CyberTruck is going to need a monster battery.
Agreed; I apologize for feeding the troll. I have estimated the battery size to be more comparable to the Model S rather than the X, though:
Elon Musk tweeted that a solar power tonneau cover option would be available that would provide 15 miles per day. I decided to try using this estimate, given the dimensions of the tonneau cover to figure out what the battery size of the Cybertruck would be.
I measured the area of the tonneau cover at about 77 in. x 77 in. This is equivalent to 41.2 sq ft. To account for error I rounded it to 40 sq ft.
77x77 = 5929/144 = 41.2
Solar panels produce a charge at a rate of
15 Watts per sq ft per hour
1 sqft = 15 Watts/hr
At 40 sq ft the solar tonneau cover would produce 600 Watts per hour
40 sqft = 600 Watts/hr
I’m guessing that the calculation was made anticipating 8 hours of full sun.
600 Watts x 8 hrs = 4800 Watts or 4.8 kW.
4.8kW gives the model S 75kWh 15 miles
4.8kW gives the Cybertruck 15 miles
The Cybertruck battery size is very close to the model S
The Model X is a heavier vehicle so it only gets 11 miles per 4.8kwh and has a range of 237 miles for a 75kWh battery. But the Cybertruck and the Model S both gain 15 miles per 4.8kWh, so they must have similar range and weight.
However, if the cd for the Cybertruck is higher than the cd for the Model S but they both charge at the same rate, the Cybertruck must weigh less than the Model S.
So for both the Model S and the Cybertruck that would be 75kWh for 250 miles, 90kWh for 300 miles, and 150-160kWh for 500 miles.
