I have a 2015 Model S60 with dual chargers. I also have my HWPC connected to a 100A circuit, so the car charges at 80A.
I’m putting in a 15.12kW solar system with 4 powerwalls (it’s scheduled to be installed on June 22) and I’m trying to figure out what to do with the car charger.
Originally my plan was to just back up the whole house, including the car charger. But I think there’s a worst case scenario where I get home from a long trip late at night, plug in the car and go to sleep. Then the power fails and the car keeps charging and drains the powerwalls and I no longer have enough power to get through the night.
If the power fails after the car finishes charging there’s no problem, or if I’m awake when it fails then I can manually stop the car from charging and there is no problem, but I don’t like knowing that there is still a potential situation where I could have a problem.
My model S is my only car, so I do still want the ability to charge it in the event of a power failure, but I want to be able to control exactly when that charging happens.
So I’m thinking I can either leave the car charger configured to be backed up and hope the worst case scenario doesn’t happen. It sounds like there is something in the works that would allow the powerwall and/or the car to control or throttle the car charging when the power is out, but that’s not available for the Model S yet. If and when it’s available for my car it sounds like it might solve my problem, so I’d just have to wait it out knowing that I have some risk until then.
Or I could put the car charger on the non backed up panel, so the car would stop charging during a power failure and then I wouldn’t have to worry about it draining the powerwalls. If I did that I think I’d also install a 14-50 outlet that was backed up, so when I do want to charge the car during a power failure I could plug the mobile charger into that outlet. Perhaps a little less convenient than just being able to use my existing charger during a power failure, but at least there’s a little more peace of mind that the car isn’t going to accidentally drain the powerwalls.
What are your thoughts?
