DefinitiveCars
So, I’m a bit confused here, Rotiforms site doesnt show these in an ET 30. Are these custom?
We can help you order 20x10 in +25 or +35 offset.So, I’m a bit confused here, Rotiforms site doesnt show these in an ET 30. Are these custom?
Maybe what they meant to say that they recommend a thinner tuner style lug nut. The factory lug nuts are the conical style (also called acorn or tapered) but are fairly fat. Many aftermarket wheels use a smaller opening for the lug nuts requiring the tuner style.Hey All,
Just ordered a set of Titan7 T-S5's (20"x10" ET40). They said conical lugs are required. Aren't the factory lugs conical already? Can anyone confirm? Yes, I'm being lazy and don't want to pull a lug just to check.
On a similar note, any recommendations for a wheel lock set?
Hey All,
Thanks for the reply and suggestion - I'll take a look.Yes, factory is conical already.
How did you come to that sizing? Take the rear wheels from the Model 3 stagggered set and made a full?
Are you looking for anything fancy for lug nuts? We have a variety of options including lock and non-locking.
The Kics Monolith T1/07 has been quite popular because all the lug nuts are uniform using an inverted Bull Lock Tuskey design.
Everything we carry is compatible with 14x1.5 thread pitch our cars uses.
Danny
No problem.Thanks for the reply and suggestion - I'll take a look.
In regards to the size, I wanted the Techna Bronze finish so the only option was to build a full non-staggered set of the 20"x10" rears from the Model 3 spec. I'm fine with this since I can run 255's all around. Much lighter than the MYP 21's too, so looking forward to it.
As of this month (May), we have been shipping factory bluetooth sensors with all Model Y wheel & tire packages (WTP). This is outlined in the description of all wheel & tire package listings.
19"
Tesla Model Y 19
20"
Tesla Model Y Aftermarket 20 inch Tesla Wheel and Tire Package
2020 Performance Y
Wheel: T Sportline Flow Forged TST
Color: Space Gray
Size: 20x10" front and rear
Tire: Michelin 255/40-20 All Season 3+ 101Y XL
Accepts: Factory Lug Nuts & Center Caps
Coming from the 21” Uberturbines and Pirelli tires, ride quality is about the same but you can definitely feel the lighter wheels in the steering wheel. Also seems the Michelin PS4S have a bit more grip and responsiveness and predictably. This is preliminary since this is only after 35 miles or so and a real review would require a bit more break-in for the tires/wheels.This look amazing.
How is the ride quality from switching to those rims and tires? I assume performance model?
Please also keep us updated with efficiency.Coming from the 21” Uberturbines and Pirelli tires, ride quality is about the same but you can definitely feel the lighter wheels in the steering wheel. Also seems the Michelin PS4S have a bit more grip and responsiveness and predictably. This is preliminary since this is only after 35 miles or so and a real review would require a bit more break-in for the tires/wheels.
One more pic for good measure
Anybody running 21x10.5 ET25? I was thinking about a really aggressive looking square setup. I am thinking ET30 may be better. Would be curious to know the most aggressive setup on here?
That’s actually my buddies car. I assume it is a Red Model Y Performance? A +40 is close to the suspension than a +25. +25 offset will poke slightly, but I want something that looks wide and meaty. I was thinking square 275/35/21’s, or 285/35/21’s.Not sure what sort of tire you'd put on the front (if a 21x10.5+25 even fits without hitting inner suspension).
I've seen an owner on a Model Y FB group run a 20x10+40 front and rear with a 275/40/20 front and a 315/35/20 rear. Looks nice and beefy. Probably kills range with all that rubber on the pavement, but I assume that owner doesn't drive far enough on the daily to care.
