Thanks.
There is slight rubbing when fully turned and reversing but that is only rubbing to that plastic insert in the wheel arches. So not really a problem and it is fixable rather easily (will do that before putting these summer tires on again).
Vossen HF-4T / Pirelli P Zero
Rear: 21 x 10.5, ET 38, 285/30/21
Front: 21 x 9, ET 30, 245/35/21
Model S owners thinking of wheel ideas, see what you think of this design.
Vossen HF4T wheels in anthracite in 21's. The S has clean body lines, so a design that's a little more complex and detailed like this one adds good contrast to the overall look. With a bit of lowering, it'll complete the look you're going for.
I’m sure there’s some range loss, but it’s a don’t care for me. Negligible probably. No regrets. Just remember that with +35mm in the back the Niche center caps wouldn’t go on since the hub screw post interfered. I’m using a small spacer to push them out a bit anyway which allowed the caps to fit.
Niche misano. 22x9 35F. 22x10.5 30 offset rear. Added 3mm spacer in front. No rub with 245 30 22 - 295 25 22 combo. Didn’t notice any range loss in comparison with the stock 19” slipstreams.
Niche misano. 22x9 35F. 22x10.5 30 offset rear. Added 3mm spacer in front. No rub with 245 30 22 - 295 25 22 combo. Didn’t notice any range loss in comparison with the stock 19” slipstreams. No regrets so far
Wow! 22s make my Misanos look paltry in comparison. We are twins outside of that. I even have a can of yellow caliper paint waiting for use as well. Well, that and black too. Can’t decide which way to go. Subtle/clean wth black calipers/white lettering or yellow with black lettering.
