Simplified Roadster Lift Adapters
Discussion in 'Roadster' started by Doug_G, Jul 6, 2014.
Tags:
  1. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    #1 Doug_G, Jul 6, 2014
    I don't believe you can still purchase lift adapters from Tesla. I have created a CAD drawing of a simplified adapter. It attaches to the car the same way the Tesla one does, but doesn't have moving parts.
    According to the owner's manual, you must first remove the rear pan from the bottom of the Roadster. Then you use two lift adapters, which lock into two alignment holes in the frame. Here's the relevant page from the owner's manual:
    I've put together an experimental design for a simplified adapter. The original adapter had this spring and lock mechanism, which is supposed to help you guide the locating pin into the chassis. From what I've heard it's not all that helpful. Instead, the procedure for the modified adapter is to lift the rear of the car slightly using a shop jack, line things up, and gently bring the car down on top the adapters, carefully re-checking the alignment as you gradually lower it.
    Here's a preliminary drawing package (USE AT OWN RISK - EXPERIMENTAL - NO WARRANTY EXPRESS OR IMPLIED):
    http://www.teslaflux.com/Adapter.zip
    Please remember this is experimental. I haven't built them yet, but I do plan to make a set and try it out. Also you may need to modify the bottom of the adapter to work with your lift.
  2. bart513
    bart513 Active Member
    East Hampton
  3. 7racer
    7racer Member
    +1!
    this is awesome!
  4. spaceballs
    spaceballs Member
    Sammamish
    Simplified Roadster Lift Adapters Part deux
    Taking page from Doug_G
    *** USE AT OWN RISK - EXPERIMENTAL - NO WARRANTY EXPRESS OR IMPLIED ***
    This is even a more basic design, I've built and used these, but I think Doug_G version is better than mine, also I think the top tip should be a little longer in my version for easier placement guide.
    The file can be opened in eMachineShop to view/edit/order the part, eMachineShop is free software.
    Note this only fits the Dannmar MaxJax 2 post car lift.
    • V1.zip
      File size:
      1.8 KB
      47
  5. Doug_G
    Ottawa, Canada
    Yeah I considered doing that, but I thought it would be safer to have a steel alignment peg. Paranoid I guess.
    I thought it best to merge these into one thread, so people can easily find both and build the design of their choice.
  6. spaceballs
    spaceballs Member
    Sammamish
    #6 spaceballs, Jul 7, 2014
    Agreed good idea to merge into one thread.
    What I mean about the alignment peg, is that my version, I found out can be longer, and I would have preferred to have it about 1/3 longer, as it would have made it somewhat easier to use.
    btw I made two sets, all out of 6061 aluminum.
  7. Doug_G
    Ottawa, Canada
    Good point about the index pin. Mine is a bit longer. In fact, it's actually a product sold as an index pin. I decided I wanted to use a steel pin for strength, mainly for paranoia's sake. That's the way the original adapter was built.
    • Disagree x 1
  8. spaceballs
    spaceballs Member
    Sammamish
    Ah I see what your saying now,
    Good idea for extra strength for lateral movement, as weight can shift if you remove/add ~1,100 pound ESS while it's being supported in the air with these things :)
  9. ElectricLove
    ElectricLove Member
    Was pricing too high on doing this in steel rather than aluminum?
  10. Doug_G
    Ottawa, Canada
    I'm sure you could do it in steel, but it would cost more to machine. Tesla's are made of aluminum, but with the steel index pin.
  11. MileHighMotoring
    Parker, CO
    Pretend there was a new Roadster owner who's got no idea what this is all about - how would you explain this to such a person, if they existed and were asking this question?
  12. ElectricLove
    ElectricLove Member
    Haha, basically these adapters are needed for putting the roadster on a 2 post lift due to the unequal weight distribution in the design of the car (the batteries in back) and the geometry of the chassis (recessed lift points in the rear). These adapters serve as spacers on one of the lift arms to give a solid hold on the vehicle while it is lifted.
    Tesla doesn't sell them any longer and a few on here have done some 3D models of such an object so that others can take that 3D model to a machine shop and have them "custom" made.
  13. djp
    djp Roadster 2.0 VIN939
    Toronto, Canada
    If you want to service your car using a four point hydraulic lift, you'll need spacers for the two rear lift points. The adapters align with guide holes in the car's frame and keep the car level on the lift.
  14. Stefan T
    Stefan T Member
    Sweden
    It works well with 2 Wood piecse in 4"X4" approc lenght of 150-200mm with a cut so the brake line not will be damige
  15. hcsharp
    hcsharp Active Member
    Vermont
    Maybe this hypothetical person knows this by now (I'm sure you know:smile:) but I have to say it... If you put your Roadster on a 4-point lift using the 4 marked lift points under the car, you will most likely have an experience you'll never forget. That experience will allow you to see what a totaled Roadster looks like.
    Using different rear lift points with the lift adapters that are the subject of this thread will enable you to safely put your car on a lift.
  16. MileHighMotoring
    Parker, CO
    Thanks - sounds like this is pretty much required if the car is ever to go anywhere but a Tesla Service Center.
  17. jeremyz
    jeremyz Member
    #17 jeremyz, Nov 20, 2015
    Here's the obligatory picture of why the lift adapters are a good idea.
  18. MLAUTO
    MLAUTO Member
    SW Florida
    You can easily lift the car without the lift adapters by positioning the rear lift arms under the rear lower control arm. SAM_2523.JPG
  19. bpangburn
    bpangburn Member
    St. Francisville, LA
    Is anyone proposing a group buy or has anyone found a local shop to machine? I'd be very interested in buying a set.
  20. MileHighMotoring
    Parker, CO
    1. bpangburn
    2. Mile High Motoring
    3.
