Yes, run everything by your electrician. If you ask to install the 14-60R this should be standard, but just make sure they install a 3 conductor + ground circuit/cable. The wall connector doesn’t use the neutral and neither does the mobile connector, but if you want to plug something else into that receptacle it may want a neutral. If you hardwire the wall connector the electrician may save money by running a 2 conductor + ground circuit since the wall connector doesn’t need a neutral. One day if you switch chargers it may require a neutral.
Ok. If you use a 14-60 receptacle with the 14-50 to 14-60 adapter do you get 48 amp charging or does the tesla mobile connector restrict you to 30 amp?
Are you getting 48 amp charging to your Y i.e 48 miles/hour charge using the 60 amp circuit with 14-60 receptacle connected to the Y using the standard mobile charger that comes with the Y?
