Last night I updated to 2.42.40 and now every 10-12 songs on Slacker in getting in-house commercials from them..4/5 times so far it's been the same one.."music news update."
Attached an example. Anyone else?
My wife noticed this too, but only occurred with "recent searches", not with some older favorites (imported from 7.1).
Same here. Have just tested this. I'm really starting to get frustrated with all these little issues that are collectively, a headache.
Do you need a Slacker account?This occurs when you have the news updates setting enabled. Email your local service center for your Tesla car-specific slacker credentials, login to slacker on the web or your smartphone, go to settings, and disable news updates. That should fix the problem. While you're there you can also enable 320kbps bitrate.
I did use my Tesla credentials and check the settings, and I have done this in the past. I also noticed the following when checking account setings:
"You are currently subscribed to Slacker Radio Plus from a gift subscription
Your subscription will expire on 12/17/2016"
I don't recall seeing this before, but maybe it's sop.
Thank you!This occurs when you have the news updates setting enabled. Email your local service center for your Tesla car-specific slacker credentials, login to slacker on the web or your smartphone, go to settings, and disable news updates. That should fix the problem. While you're there you can also enable 320kbps bitrate.
I did actually!Did you by any chance get your Tesla in December 2015? The account for my Tesla expires in 3/17, which will be one year after purchase of the car.
It doesn't really expire. It just says that.Did you by any chance get your Tesla in December 2015? The account for my Tesla expires in 3/17, which will be one year after purchase of the car.
In other threads on this it was said Ingineer or wk57 found that Tesla's now using the parameters hard-coded into the access URLs, so changing settings on the account is no longer effective. I don't know if that was only for bitrate, but may apply to this issue as well.This occurs when you have the news updates setting enabled. Email your local service center for your Tesla car-specific slacker credentials, login to slacker on the web or your smartphone, go to settings, and disable news updates. That should fix the problem. While you're there you can also enable 320kbps bitrate.
The login and password are hidden but your service center will share it with you if you ask.
Yes hereLast night I updated to 2.42.40 and now every 10-12 songs on Slacker in getting in-house commercials from them..4/5 times so far it's been the same one.."music news update."
