I would feel safe if I had my 1911 with me and if I am sleeping in my car I will have it with me.I spend a lot of time on the road. Ski trips, road trips, camping/backpacking. On occasion I will sleep in my car while charging, usually at night, either briefly at a Supercharger or for an extended period at a level 2 charger.
I've never had bad experiences, but in the back of my mind I do worry about vandalism or a confrontational crime, especially in less nice areas. Obviously if I am sprawled out in the back I am not in a great position to defend myself or my vehicle. And even if I stay in front, it's not like I can drive away if a danger approaches, as I am plugged in to the charger.
I'm sure the risk of such thing a thing happening is low. But, a low number times a high frequency is a higher number, and Model S is a nice looking car, and I worry it carries an elevated risk of being targeted.
Does anybody else do this, or have similar thoughts? Any ideas for maximizing safety in these situations?
The biggest issue I see is that you can't drive away without getting out of the car to disconnect the charging cable, so even if you identify a situation that is potentially unsafe, your avenue for escape is limited.
I've actually seen someone plugged into a supercharger drive off without unplugging, so don't let the fact that you are plugged in keep you from putting your personal safety first.
How is that? I suppose it is possible if you leave the connector in the port unlatched since if the car is plugged in and you step on the brake to start the car it beeps at you and says to unplug the car to put it in drive.
STAY IN YOUR CAR if you are being harassed. Honk the horn and call 911. Drive off and yank the cable out of the supercharger if you have to.
It won't let you drive at all if it is plugged in.
We need an "Emergency Eject" button -- but that would take a redesign of the port or cable.
... or someone can find a way to modify their car to tap into the battery current and electrify the car frame if they feel that unsafe lol.
Brings up a good point...
What about an option to unlock the charger while in the car so you could drive off without exiting the car. Yes, it might damage the cable end by falling on the ground, but at least you could get away if in a bad situation.
Even in cases where there isn't much going on like Springfield, OR I still found it rather uncomfortable. One of these days I'll try putting a blowup mattress in the back to see how that goes.
