You brought up seatbelts, so no, you didn’t stick to AP.
Nor did I claim to.
Are you high or something?
The post you're replying to has me specifically citing seatbelts.... as an example of another thing the car maker does not put a hard disable on if not using it correctly.
That was the entire point of analogy in fact.
Actually, i never took a position on the other two.
Other than to, wrongly, claim you'd need to spend lots of $ adding hardware for the car to tell if your seatbelt is on...
Which admittedly was
hilarious to watch.
But the other two aren’t relevant to the topic
Of course they are.
They're additional examples of things it's the drivers responsibility to handle properly- that the car maker could
easily take away from the driver in the name of "moar safety" but they don't.
Nobody does.
Thus.... showing how ridiculous and out of touch
your original suggestion for them to disable AP to do that was.... since it was the
least dangerous thing of the three as far as killing anybody.
You provided a owners manual that stated it was set up to disable airbags, not disable the ignition
Which, again,
nobody suggested made any sense to disable, ever, other than you
You'd disable shifting into gear.
(or shift into gear) which is a completely different system.
Are you seriously
so ignorant of all cars made in the last couple decades as to need
proof that they already have[/B} the hardware to prevent you from shifting into gear unless specific conditions are met?
You really need someone to quote the owners manual on THAT too?
Ok, but is there a difference in your point whether it disables the ignition or disables shifting into gear?
Well, yes.... one is much dumber than the other. For several reasons already mentioned.
And of course it's the one you picked and nobody else ever suggested.
The question is “if you want lockouts on ap, shouldn't you want lockouts on being able to drive the car with your seatbelt unfastened”, correct? I’m not sure i’m understanding the distinction you are trying to make.
Meanwhile everyone else is sure you haven't understood a damn thing all discussion
1 + 1 = 3 is your argument....
w can detect x. y can control z. x can control z.
...no.
Not even slightly.
You do understand all modern cars have computers-- right?
So that the control systems and sensors can all talk and coordinate with each other.... right?
So to correct your, once again, horribly nonsense programming analogy:
The sensors can detect X. Which they then tell to the computers controlling the car. Cars do that TODAY.
The computers can lock out shifting into gear unless specific conditions are met. Cars do that TODAY.
The computer can have an additional condition added to that check. Even cars already on the road can have that added. Cars do that TODAY (though for everyone buy Tesla you need to bring it to a dealer to flash the computer).
So all new cars today can already add such a seatbelt lockout with zero added hardware
Like you've been corrected on about 10 times now.
Where'd you get lost this time? Did you find a pretty rock and get distracted or something?
While we're at it- let's get back to your original post on this nonsense-
Adding speed limiters and searbelt interlocks on every care would add a lot to the cost of most cars. what similar cost (or negative) does locking AP have?
So we've debunked the seatbelt thing pretty heavily...
How bout the locking out driving over the speed limit?
Do you also think new cars already can't do this?
I ask- because generally new cars today already have an active max speed limiter it's just a lot higher than the speed limits in the US.
I imagine there might be exceptions, but it'd be trivial to add them via a software flash- again with $0.00 in new hardware.
It must be exhausting for you- being wrong so much....
