  • The final cut of TMC Podcast #27 is available now with topics time-stamped. We discussed: Consolidation in LiDAR manufacturers; Volvo EX90 shipping with LiDAR; FSD Beta Full Release in N.A.; FSD detecting autopilot cheats, Gwen Shotwell directly overseeing SpaceX Starship; and more. You can watch it now on YouTube. We should have it published to podcast networks shortly.
So what's the latest best practice to avoid AC smell happening in new car?
I'm aware a SW update was released that was supposed to address this issue. But are there still best practices that need to be followed to avoid the smell long term? Does anyone know what the SW update actually did?
Should Cabin Overheat be set to fan only, for example?
Any examples of newer cars getting the odor?
Eno Deb
2,641
3,402
SF Bay Area
During the last 5 minutes of driving, turn off ac, turn off recirculate, turn fans up to 7 or so.
The car automatically runs the fans after about 10-15 minutes when you park it after having used the A/C. Turning the A/C off before you park may actually defeat this (haven't tried it though).
It's now been 3 months since I cleaned my evaporator and changed the filters. The smell hasn't returned. I'm not doing anything special.
Talked to a mobile service tech. He said use the fresh air setting rather than recirculate is the best way to prevent it. Particularly if it's dry outside.
AC on Auto always and no smell. The additional running of the fan on a past update also helps.
This is not a Tesla problem. Every car I have owned lately will do this if you stop the car with AC running without letting coils warm to prevent condensation puddling.
Technically, with the firmware change to actively dry the coils after use, the Tesla is even less likely to experience this problem vs. needing to remember to do it yourself before you stop the car.
Reactions: jdcollins5
WilliamG
Hinge Fanatic
Apr 20, 2019
6,721
10,615
Seattle, WA
I never use recirculate. Just so nasty, and means windows steam up so much more. Fine, it may use a little more power to heat the car in the winter, but it's worth not a) getting sick, and b) being able to see out the windows.
Reactions: XLR82XS
I never quite understood why this would work. If you're pulling in fresh air, that outside air is usually more humid than the recirculated air.
The way I understand it, especially with ICE vehicles, is to equalize the temperature between the hvac and the environment. Having your car on recirculating creates a cold and closed space while the environment is hot (especially the engine bays of ICE vehicles).
If you shut your car off in that state, the air condenses and creates moisture. There is limited routes for the air to escape as well since the inlet vent is closed.
That's how I understood it, but I'm no expert. It's been good practice to do this on all vehicles including ICE vehicles. BMWs are notorious for this issue because some models always turn recirculate on when in AUTO.
Reactions: rhaekar
That totally makes sense. I've done some home remodeling myself and when doing construction, anywhere hot air meets cold surfaces it creates condensation on the cold surface so that's when you need to introduce a vapor barrier to prevent mold growth.
Reactions: m3supra
