Tesla said:January 2021
Version 20.49
Improved security for local gateway interface for Gateway 1 and Gateway 2
Updated support for utility grid connections in Japan, Italy, Germany and Switzerland
November 2020
Version 20.40
Improved multiphase metering for Gateway 2 systems
Improved off-grid and backup heat mode behavior
Updated version number scheme for software releases
Any idea what improved GW security means?
For anyone ending up here, see solution at Tesla Owners API v3 enabledLooks like /api/system_status/grid_status on the TEG is no longer open. Time to update more scipts ...
I have not been able to connect using my web browser since the update. It isn't recognizing my credentials nor will it allow me to change my password. I even tried cycling one of the powerwalls per the instructions on Tesla's website. I filled out a contact form almost a week ago and haven't heard back.Our software was updated to 20.49.0 last week. I typically have a web browser open to the gateway throughout the day so that I can monitor production and consumption. I noticed that the new security requires me to log in whereas I could view this information without logging in before. Is anyone else having the problem where the login only works once? I've used the option to reset the password twice in the past week. It works and allows me to log in and view the power flow animation, change network settings, view the summary, etc. However, when I try to log in again the next day, I get the message that my credentials are bad. Is anyone else having a problem logging in? I know I'm using the correct password as I keep setting it to the same thing and have confirmed with a screenshot that I'm entering the correct password.
I guess that's "good" to hear I'm not the only one having problems with credentials. We've been able to change the password by cycling the switch on a Powerwall but then the password only works once.I have not been able to connect using my web browser since the update. It isn't recognizing my credentials nor will it allow me to change my password. I even tried cycling one of the powerwalls per the instructions on Tesla's website. I filled out a contact form almost a week ago and haven't heard back.
Hopefully the next update fixes the credentials issue.
Since you have automated scripts, I'm betting they are keeping your session active and the password isn't expiring. I did notice that before logging in, it does show Registration: Incomplete. I'll try resetting the password again and see if I can complete the registration and see if that makes any difference in the password persisting.I have 20.49.0 and use the local API quite extensively. Once my system was upgraded my scripts all started to fail. I then logged in directly to the TEG as customer and it said the system was not registered. I ran through the wizard and the system's status came up on the web site. I then updated my scripts to refresh the auth token every hour (which is overkill - I'm sure the token actually lives longer than that) and it's been working fine since. Never had to change the password and my previously set up user password worked post "upgrade" to 20.49.0. Another thing to note is that the email address doesn't seem to be used for authentication, I use [email protected] but with the right password and it works fine.
I am still showing registration incomplete (despite multiple attempts,) but I have no trouble logging in (switching the login type to "customer".) I am currently set to the default password, and, as @gpez noted, I found that it does not matter what email address is provided.Since you have automated scripts, I'm betting they are keeping your session active and the password isn't expiring. I did notice that before logging in, it does show Registration: Incomplete. I'll try resetting the password again and see if I can complete the registration and see if that makes any difference in the password persisting.
