Solar Eclipse Could Affect the Grid
Discussion in 'Energy, Environment, and Policy' started by S'toon, Jun 23, 2017.
  1. S'toon
    S'toon Knows where his towel is
    AB
    Full article at:
    Solar eclipse in August raising worries about Ontario's power grid
  2. Ampster
    Ampster Active Member
    Sonoma, California
    The President of the California Public Utilities Commission expressed some concern as well. California is not even close to the main shadow area.
  3. SageBrush
    SageBrush 2020: Drain the Sewer
    New Mexico
    How long will the eclipse last ?
  4. NikeWings
    NikeWings Active Member
    Several months ago I read an interesting bit which revealed a 1/3 of CA power is imported due to growing sources of intermittent power gen within the state. Mostly from the NW and SW.....maybe the shadow will be impacting production zones typically relied upon by CA.
  5. NikeWings
    We'll be watching from Jackson Hole and it's estimated start/finish for about 2:45 mins, although totality is only 3 minutes or so.
  6. nwdiver
    nwdiver Well-Known Member
    United States
    If only there was a way to know precisely when this is going to happen so we can be prepared :)
    • Funny x 4
  7. GasKilla
    GasKilla No Gas Know Peace
    Los Angeles, CA
    Just like "nobody could have predicted the breech of the levees" this is just something we'll have to deal with if it happens
  8. idoco
    idoco Member
    Outside Philly
    Doesnt' this happen every day, aka night, without armageddon happening?
    • Funny x 3
  9. RandyS
    RandyS Fan of Elon
    San Diego
    Idoco,
    The challenge to this particular situation is the solar power level at the time that will be lost and the short nature of the dip it will cause.
    Fossil fuel plants are not known for their instantaneous ability to ramp up, but batteries can. There just aren't enough battery resources yet installed.
    In San Diego, the eclipse is only rated at a level of 50%, but we have well over 500 MW of rooftop solar generation online. So within a 3 minute period, if it turns out to be a sunny day - and it probably will, I would guess we could lose at least 300 MW of generation and then have it "come back on" in 3 minutes.
    So to keep the power system stable, it's really two event, the loss of that much generation, and the reappearance...It will be interesting, that's for sure....
  10. bxr140
    bxr140 Active Member
    Bay Area
    So basically, it's like nighttime, but only for a couple minutes?
    • Funny x 2
  11. ReddyLeaf
    ReddyLeaf Active Member
    Pasco, WA
    • Informative x 2
  12. Ampster
    Sonoma, California
  13. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Here is a graph showing the dip in output of my rooftop solar system during the eclipse as experienced near San Francisco.
    • Informative x 2
  14. Ampster
    Sonoma, California
    Yes the CAISO graph of solar output looks similar. The grid was resilient and I have not heard of any glitches.
  15. swaltner
    swaltner Active Member
    Kansas, USA
    @ecarfan, thanks for bringing this thread up to the top. I briefly looked for it, but didn't find it.
    It's really interesting in the difference between the visible light change and the solar irradiance during an eclipse. People seem to intuitively judge the impact of the eclipse on solar production based off the rate at which the light drops. The amount of light doesn't seem to change until right around totality, but in reality, there is a gradual decrease in the amount of solar irradiance over the whole ~3 hour event. So the grid is adjusting over a 3 hour period, not a 3 minute period. Not to say the grid operators don't have to plan for it, but it's a much easier problem to deal with than what I was originally imagining.
    Here's the graph from my solar system. I was a little close to the center line, so 93% coverage instead of ~73% coverage that resulted in your solar output graph. Partial eclipse time here was 11:36 through 14:04, which lines up exactly with the trough right in the middle of the day. It wasn't a clear day, so my production graph isn't a clean curve, but you can definitely see the impact of the eclipse.
  16. mblakele
    mblakele pre-jackpot member
    SF Bay Area
    I figure I lost about 4% for the day. I'm sending the bill to the moon.
    As expected there was no impact on the grid, which is great. Talking about it can also help raise awareness of the importance of grid-attached storage.
