I haven't read / remembered your circumstances, so this may be irrelevant in terms of comparison two configuration proposals.
Rather than total generated p.a. I would be interested in amount generated at the start / end of the day. If your different scenarios would make more available at start / end of the day (in particular start-sooner and finish-later) that is likely when you would be at home and using it, whereas more at the peak of the day is likely to be "too much". It can charge a battery, provided not already full. Can export too - if you are getting a decent rate for that (and can arbitrage against night-time usage)
The benefit of early-start / late-finish is both the likelihood that you are home and can make use of it, and also it shortens the non-solar night, so battery has to cover for shorter night duration - which becomes more important in the shoulder months
