How have others with an AC battery and Zappi got it all set up?
I have Zappi (as my second charger, the other is Tesla (dumb).
I assumed I would use Zappi for overspill to car (when it detected PV excess was exporting to grid)
I don't use it like that, I just have it in "dumb" mode, and control everything from the car
If I come home and want to charge (immediately) I don't want to have to tell car to charge and also override Zappi (and remember to un-override it later)
If a mate comes and plugs in I want his car to start charging without me having to override / disable Charger schedules etc.
If I plug Car-A into Charger-B, instead of its normal Charger-A, then schedules / preferences defined at the Charger would be wrong for the car. I think this will become a snag as people acquire 2x EVs and chargers
When my Home Help has an EV I'll be very happy they plug in and use up my excess PV once my car is full (and assuming Octopus is not paying me handsomely to export
If car is charging from PV and PV stops generating I want something to decide what to do. Stop/Starting is not good for the contacts. Zappi has a "tolerance" to carry on for a bit before giving up, but I think its a bit of a blunt instrument approach. My API homebrew stuff will reduce AMPs if the PV power falls, and will allow the Battery to drop a couple of percent before actually stopping charging. When PV resumes it will stay on low AMPs (if it hasn't stopped) until the battery has regained that 2% and then ramp up
Also, my case is a bit non-standard, my PV generates 14-15kW at peak. Charging battery first, and then car, means that car will take max 7kW so I'll be exporting. And I think Powerwalls charging at the max 10kW is not ideal for longevity, so if my API-thingie reckons its going to be a bumper PV day it charges car concurrently whilst the battery charges, to reduce kW to the battery, make the battery keep charging to, say, 3PM before reaching 100% and then the PV output has fallen such that car taking 7kW is more than the excess coming off the PV
