I had an extra 30 min IO slot this morning between 5:30 and 6:00 and the Zappi did draw from the Powerwall as you describe ... A bit annoying as it used 10% of the Powerwall before we’d even woken up
It’s all very new to me but I guess I could change the Backup Reserve setting to 100%. That would still allow it to charge but I think would not discharge.Just thinking out loud:
Could you (some how ...) change the PowerWall to 100% to stop it discharging during one of those periods? (and that would also mean it would Charge, if lower than that ... although (if not part of the PowerWall Timer Schedule) only at 3.5kW (i think) rather than 10kW (unless the API has improved to allow controlling that)
Yes, you have stumbled across the one snag of the IO/Powerwall combo.It’s all very new to me but I guess I could change the Backup Reserve setting to 100%. That would still allow it to charge but I think would not discharge.
The only downside I can see is that between the end of the IO off peak schedule and the point I’m awake to change the reserve setting, the house would draw from the grid at peak rate, although this would be fairly minor usage at that time of the day. I’m sure there would be a way to automate it with Home Assistant but I’ve only just started messing around with that so need to research.
Just split the mains cable to a seperate consumer unit for charging before any Powerwall related sensor so the Powerwall knows nothing about the electricity the EV is taking.
I dont know if it depends on the area but over here I get slots for most of the day. Adding slots to the app is one way to deal with it BUT you must remember to remove or adjust for the next day. Setting the backup to 100% does the same BUT you must remember or set an alarm to put it back down for when the slot ends.... It's a pain in the BUT.Yes, you have stumbled across the one snag of the IO/Powerwall combo.
It’s not that usual to get charging slots outside the 23:30 to 05:30 hours but it does happen sometimes.
The way I usually deal with it is to check the charging slots just before going to sleep (they can change sometimes) and adjust the peak/off peak tariffs on the Powerwall accordingly.
Oh, that’s really interesting.I dont know if it depends on the area but over here I get slots for most of the day.
That’s an option, but I have 4 Powerwalls, so they can charge at a rate of 20kW from the grid (they usually stick to around 14, but they definitely have the capability of going higher).Just split the mains cable to a seperate consumer unit for charging before any Powerwall related sensor so the Powerwall knows nothing about the electricity the EV is taking.
- you can charge your car during a power cut (although why would you?)
Glad to see I'm not the only considering the ApocalypseAlso... when the Zombies come...
Indeed.... We need all the hardware we can getGlad to see I'm not the only considering the Apocalypse![]()
I was surprised to find the Powerwall had only charged to 70% last night
Is this likely to cause early degradation of the battery?
is it better to let the AI do it’s thing but risk it sometimes getting it wrong and not charging the battery enough for a days use?
I’ve been playing around with different reserves and had that set to 5% last night which is the level it was at when it started charging in the off peak window.What was your state of charge by the time it started charging from the grid last night?
Until I get my export MPAN I really want to use all the solar I can and export none ideally. So letting the AI leave some spare capacity in the battery for the expected solar generation was a good move today.I take an "assume not" view - Battery intended to be charged and discharged, fully-ish, at least one cycle every day.
Well ... that depends how much you pay for Peak tariff. There was some chatter on here a while back that even a short period of Peak Tariff - e.g. if the guestimate of Sun for the day is too ambitious - negates all the saving if you run out - or even if you fail to get to 100% during the day, and it was better to Export some (particularly if the Export rate is more than Tuppence), rather than run out. Also, this time of the year, there is a lengthy interval between end of Off Peak and Solar generation exceeding house usage (more so if PV is South facing (than East), a lot more if it is West facing
I think it depends a bit if you can charge a car. This time of the year I rarely get more than 3 or 4 kWh of export ... the car pretty much always has room for that ... and Tesla's charging estimate of "tomorrows sunshine" has no account for what my car can take NOR whether I am about to go somewhere. So forcing the charge to 100% is fine, in my view, if you can dump any Export into Car ... or even to Export it.
