I have just placed an order for Solar Roof + 2x Powerwall to replace an existing 4kW solar panel system installed in 2000, but I'm concerned that we might not get approved for a building permit. My city Sunnyvale (Santa Clara County, N. Cal) Building Division re-roof requirements includes:
Roofs Exceeding 7.5 lbs./Square Foot
New roofs that exceed a total weight of 7.5 lbs/SF (including sheathing and roofing material) may require additional roof framing and support. Information about the existing roof framing will need to be provided to Building Division staff at the One-Stop Permit Center for specific direction on a particular project.
Has anyone here had a problem with this in Sunnyvale or similar requirements in other jurisdictions due to the weight of the Solar Roof tiles?
When we were planning our PV system installation in 2000 we initially wanted to install Atlantis Energy SUNSLATES which was a system somewhat like the Solar Roof but using Eternit cement/fiber imitation slate tiles as the substrate with a glass-covered PV module applied to the tiles in the active area. The weight of the plain Eternit tiles was 5 lb/sq.ft. and 7.2 lb/sq.ft. for the SUNSLATE tiles, not including the weight of the plywood sheathing. We contracted for an engineering analysis of our roof framing that found the framing to be adequate for the static load, but the City of Sunnyvale wanted a lateral load analysis including a shear wall analysis because of all of the added weight on the roof. The structural engineer said that based on the date of construction of our house (1980) it would likely not have adequate shear wall design and the load analysis would not pass. So at that time we simply renewed the wood shake roof at the same time as we installed 4kW of solar panels. Now our insurance company is requiring us to replace the wood roof and the existing solar system has degraded so I'd like to replace both with the Solar Roof but I'm concerned about the weight.
I have not found any Tesla document with technical specifications for the Solar Roof tiles, but what I've found on the web is that the PV tiles weigh 7.34 lb/sq.ft. and the inactive tiles weigh 4.15 lb/sq.ft. That's comparable to the SUNSLATES. With plywood roof sheathing and membrane the total weights would be about 9.3 and 6.0 lb/sq.ft. Has anyone here encountered a problem with the roof weight?
