Lots to cover here, gonna try to do it in a single post....
Deployment was kind of anti-climactic, I would have liked an animation or something showing how the constellation spreads out from the initial blob.
I mean, it was never going to fling them out, but yeah a time lapse animation would be cool.
Looks like the 'spin' we've been hearing about was a slow rate in yaw (think: slow-mo version of Mav and Goose in the flat spin) and, most curiously, the stack had a roll angle somewhere around 45 degrees.
Never expected the sats to all fall off at once! So I guess they reach 550kms and a spread out constellation over, what, days? Weeks??
Weeks for sure, I'd bound between like 2 and 10. Gut feel is something in the 4-6 week range. It all kinda depends on the size of the thruster. Less thrust = longer time required for the various orbital manners.
https://www.starlink.com/images/satellite/satellite__SOLAR_DISPLAY.jpg
Definitely looks like there will be some gravity gradient aspect to the attitude control, though its tough to say how much. The Solar arrays are pretty thin and surely don't weigh that much.
https://www.starlink.com/images/satellite/satellite__ANTENNA.jpg
In that image you can see three copper color hoops which are the features that secure the sats to the gold launch structures we talked about that run up the length of the stack. During the
convenient "planned loss of signal" those launch structures were ejected somehow, then when the feed goes back to the first seconds of deployment you can see one row of those hoops.
Another cool thing in the shot just before the convenient feed cut out, there's a row of sort of gold brackets hanging off the sats with a while not-quite-circular feature in the middle of those brackets. That's a GPS antenna.
Oh wow, no sat to sat links. Didn’t know that. SpaceX is really developing this network in real time aren’t they? I suspect they are finding or are going to find that station keeping for laser links is going to be tricky, not to mention Sun interference, etc.
Laser links are, unfortunately, expensive and difficult to create. And, when you don't have a lot of sats in the network the laser links have to look farther away and at different angles. Its plausible that the ISLs SpaceX is building for the network simply can't close the loop with the small number of sats, so they opted to save the money and not launch them...? Having no ISLs makes the sats pretty low value on their own, but certainly spaceX is going to learn a lot about all the functionality that's on these spacecraft and how to improve that functionality in the future. There's no testing environment that can match the one you get on orbit.
SpaceX filed for a temporary exception for Starlink to allow them to use them during orbit raising and positioning.
The nuance here is that they would not be able to concurrently perform orbital maneuvers (firing the thruster) and simultaneously use the payload. The major reason is that both the payload and the electric propulsion system require significant power; the power system would not be sized to have both on at the same time (not to mention there's probably thermal problems with that too...). There's also a geometrical requirement to align of thrust vector, [satellite] velocity vector, and center of mass during thruster firing...though...if you look at the wire-frame sat in the solar array image linked upthread, you can see the hall thruster offset right of center along the top edge of the satellite. That offset location is certainly to align with the center of mass, I wouldn't be surprised if SpaceX sharpened their pencils to also have it align with the velocity vector.
Anyway, if I were to speculate, I'd say the exemption is
really in place because either a) there's some planned time delay in starting orbit raising of some sats vs the others and so you might as well fire up the payloads on the sats that are going to be sitting around for a little while or b) in the event the propulsion system fails or in some other way doesn't perform as expected they can just fire up the payload in whatever orbit the sat ended up in.
The thing is old school sats at GEO could take weeks to get into position...
There's a bit to unpack in that statement. GEO sats get to GEO altitude like 10-11 hours after launch or something. They don't have one big delta-v event though (like you'd get in a classic Hohman transfer) but rather fire the main thruster a number of times over a few days to de-incline, circularize, and phase. So they really take days to 'get into position'. Note that most actually don't start out in their revenue-generating orbital slot but rather spend the first month in a different slot positioned above whatever ground station they're using for in-orbit test.
The exception to the above is if a satellite is using electric orbit raising--which is still quite rare these days--which turns days into months. Typically 2-6 months, depending on what orbit you start in.
