SpaceX Internet Satellite Network: Starlink
Discussion in 'SpaceX' started by Grendal, Nov 8, 2014.
  1. GoTslaGo
    GoTslaGo Learning Member
    US
    I find it interesting that one company is planning 720 satellites to cover broadband for ALASKA (only I assume).
    That gives one an appreciation of the scale of coverage that would be needed.
    Hence the 4400 LEO followed by 7k+ lower orbital satellites planned by SpaceX.
    (In comparison the 108 planned by another company seems.... paultry).
  2. MitchJi
    MitchJi Trying to learn kindness, patience & forgiveness
    Marin County, CA
    Exactly! I can't wait to replace Comcast. The fact that I'm confident that Elon will support net neutrality is an added benefit!
  3. djplong
    djplong Member
    NH
    As much as I followed this, I missed Elon saying the antenna would be the size of a pizza box. I've had hopes on there being a mobile version of this - something that would fit on a car. That would mean Tesla could tell AT&T to go pound sand and not be susceptible to dead cell spots for it's telematics and use Starlink instead.
  4. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Yes, he’s made that statement a number of times. The planned size of the receiver could certainly fit on a vehicle, but I don’t think it will be something that you would have permanently mounted unless it was something like an RV where you didn’t care about aerodynamics.
    It appears that Starlink is not intended to be a service like Inmarsat satellite phones where a mobile phone can communicate with the satellite fleet directly. However, I wouldn’t rule that out in the future...
  5. Tyl
    Tyl Member
    Phoenix East Valley
    Now if we could only get a powerful LED facing downward toward earth with Li-fi.
    Light fidelity!
    That’s the ticket!!!
    but I guess clouds would be in the way
  6. ccutrer
    ccutrer Active Member
    Eagle Mountain, UT
  7. e-FTW
    e-FTW New electron smell
    San Francisco, CA
    Just curious: was there a response there @ccutrer ?
    Or is it a bug that I saw nothing except the quote? Honest question, as I've seen this before.
  8. mongo
    mongo Well-Known Member
    Michigan
    The reply is in the quote, the square brace in the end quote tag was deleted.
    I'm wondering if they have a low cost phased array designed. It seems like beam steering would be needed due to the rapid movement of the satellites.
  9. bxr140
    bxr140 Active Member
    Bay Area
    That’s not how it works. Oneweb is going for global coverage with 720 Leo spacecraft in a number of different orbits, and the entire quantity (more or less) is required to provide full service globally. As the constellation is rolled out there will be gaps in both coverage and bandwidth, because you can’t launch 720 spacecraft at one time. Alaska makes sense as a pilot region because many of the orbits converge at high latitudes, so you could end up with a good amount of coverage for a fairly small number of spacecraft. It’s also mostly a first world area with presumably a fair number of people that don’t have but do want high speed data, so you can realize revenue sooner.
    It’s all about the capacity and coverage of each spacecraft—comparing quantities does nothing to indicate total performance.
    More spacecraft means more launches, which for the foreseeable future (despite predictably grand claims by Elon) are going to be the long pole. So fewer launches with higher performing spacecraft can get your network to saleable capacity faster, not to mention the lower volume is less of a paradigm shift on a traditionally low volume supply chain for space hardware. On the flip side more smaller spacecraft are easier to industrialize, and impact total network performance if a single unit suffers an anomaly.
  10. DurandalAI
    DurandalAI Member
    US
    Bring it! I can finally have high speed internet and tell AT&T where to shove it.
  11. ecarfan
    San Mateo, CA
    The SpaceX Starlink system will provide global high speed/low latency internet access via a constellation of 4,425 small satellites in LEO. We really don’t know much beyond that.
    See Iridium | Services . Iridium does offer broadband. The two companies clearly are competitors.
  12. ecarfan
    San Mateo, CA
    I’m quoting that from another thread. ;) But I don’t find an “official” thread for the Paz launch, so thought I would insert it into this one.
    I have not seen anything official from SpaceX regarding what will happen to the Paz first stage after launch. Hoping to learn soon. Am considering going to this launch. If the weather is clear, it could be quite spectacular: launching in darkness at 0622 and flying up into sunlight a few minutes later, maybe?
  13. Grendal
    Grendal SpaceX Moderator
    Santa Fe, New Mexico
    Ooo, a repeat of the Iridium launch where most of LA thought they were being bombed or invaded by aliens? That would be cool. Good luck.
  14. Mike Smith
    Mike Smith Active Member
    Toronto
  15. elasalle
    elasalle driVIN(188xx) it !!
    VA
  16. Waiting4M3
    Waiting4M3 Active Member
    San Jose, California
    At least in the US, if there was ever an industry that deserves to get disrupted, more so than the traditional auto+dealerships, it's the TelCos.
    • Like x 5
  17. GoTslaGo
    US
    The profits will flow to Tesla investors if Starlink proves to be an important element for Tesla Network.
  18. mongo
    Michigan
    If Tesla can switch from paying cellular data service rates to a lower cost SpaceX system, that will improve the bottom line. Especially with a goal of million of vehicles on the road, each with a data link.
  19. elasalle
    VA
    Semi-agree, but other players will not need Starlink to do network, GPS stuff ? Also, TSLA will have to buy these services at specified rates from SpaceX, and SpaceX will likely need to make all their services available to all parties at the same costs ...
    Edit. As a non Tesla owner, my understanding is currently internet services are free. In future that might not be the case and yes they could monitize it some ..
  20. ValueAnalyst
    ValueAnalyst Closed
    World
    I wouldn't expect other automakers rushing to contract SpaceX's services, just like they're not rushing to use the Supercharger network.
