SpaceX Internet Satellite Network: Starlink
Discussion in 'SpaceX' started by Grendal, Nov 8, 2014.
  1. DMC-Orangeville
    DMC-Orangeville 85D and John Deere 5100E
    NW of the 6ix Canada
    Go here: Starlink
    Enter your email address and address of the new property......verify the google earth location, and see if you can get service now.
    I tried...my house doesn't qualify (43.56 latitude), but my cottage, north east of the house does (44.52 latitude). My understanding is that the current beta service is between 44 and 52 degrees
    • Helpful x 2
  2. Discoducky
    Discoducky Happy owner of a P100D X and a brand new 2021 M3!
    Seattle
    Yep, already did that and I qualify (47 degrees), but I'm also in the Seattle area so I'm thinking they might be max'd out here. Regardless, I'll suffer with a 5G hotspot if StarLink doesn't work out in the short term.
  3. Cosmacelf
    Cosmacelf Well-Known Member
    San Diego
    Where's the house? Try applying again - people are finding that sometimes they can order a terminal right away without having to wait.
  4. Discoducky
    Seattle
    I just applied today. Will try again tomorrow ;)
  5. webbbcam
    webbbcam not-so-junior member
    Coeur d'Alene, ID
    Agree with Cosmacelf. No harm in reapplying.
    I applied for my lake home in Hayden (lat 47.76) months and months ago and got nothing. On a whim reapplied early January, got my acceptance email on 1/14. Ordered (paid) on 1/16 and just received the dish tonight via fedex.
    Excited to drive up to the lake this week and test it out.
    • Like x 5
  6. HVM
    HVM Savolainen
    Finland
    • Informative x 3
  7. Cosmacelf
    San Diego
    Wow. Once again SpaceX moves fast and breaks things. Didn't the opportunity to even launch polar sats come together at the last minute? They realized they had enough payload capacity for 10 polar sats on this ride share like in November so they asked the FCC for a permit exception to launch. FCC granted the permit in a few weeks, and then SpaceX had to integrate the ten sats (at the bottom of the stack!) onto Falcon 9 in a hurry. Somewhere along that timeline, they fitted ten prototype laser links onto ten Starlink sats, because only these ten sats have lasers.
    Talk about an agile company!
    • Like x 4
  8. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    They had already launched satellites with space lasers and tested them, so I don't think it was a huge deal.
  9. Electroman
    Electroman Supporting Member
    TX
    Aren't lasers extremely narrow beam. How are they able to have a laser from one satellite point precisely to another one that is 100s pf KMs away and also moving at an incredible speed? Or maybe that is not how this thing works?
  10. bxr140
    bxr140 Active Member
    Bay Area
    Were there ISLs on any of the production starlinks? To my recollection it was only the two prototypes, and those seemed to be big, expensive, externally procured units.
    Relative to each other, the satellites are moving extremely slowly. Think of cars on the freeway, all traveling about the same speed. Absolute speed is 70mph, relative speed is 2mph. The in-plane satellites almost have literally near-zero relative velocity to each other. Cross-plane interlinks are where satellite velocities end up non-zero, but those velocities deltas are also very predictable/sinusoidal.
    Note that both tracking heads (one on each sat) have to track each other to close the link.
  11. Cosmacelf
    San Diego
    Point to point laser communication system have optics which focus or defocus the beam to take into account movement jitter and also bit rate. For example, if you only needed 1 Mbps of bit rate, you probably could defocus the laser beam such that it was 500m in diameter at the receiving satellite thus giving you a lot of error margin in pointing the lasers and receivers at each other. Higher bit rates are going to need tighter beams, but there is still going to be quite a bit of directional slop available at the receiving sat.
    Add in the fact that each satellite is essentially stationary relative to each other in the same orbital plane, and that there is no atmosphere to muck up the beam, and you've got a pretty stable communications link.
    Lasers for satellite to satellite communications I believe are a well established technology - as usual with SpaceX, the challenge is to make them cheaply.
    • Informative x 2
  12. Cosmacelf
    San Diego
    As bxr140 said, AFAIK, there were only two satellites launched with test ISL links. No doubt these lasers are a newer version. And if my time line is correct, it was a very big deal. But whatever.
  13. e-FTW
    e-FTW New electron smell
    San Francisco, CA
    Pretty darn cool visualization tool for Starlink orbits: Starlink
  14. Cosmacelf
    San Diego
    polar sats aren’t there yet. I guess they are still getting into their correct orbit.
  15. 1965Falcon
    1965Falcon Supporting Member
    Vancouver, WA
    I just signed up for the 4th time, crossing my fingers!
  16. e-FTW
    San Francisco, CA
    Yup, 15 is the last batch there. Others not yet up to the correct orbit?
    1208 Active Member
    UK
    • Informative x 3
  18. dhanson865
    dhanson865 Active Member
    Knoxville, Tennessee
    #1498 dhanson865, Feb 6, 2021
    a snapshot of the orbits. Reminder: orbits shift from left to right (or is it right to left), either way that lone "polar" orbit will cover the entire map, just takes several days to work it's way around so those regions only get coverage for a few minutes here and there.
    • Informative x 2
  19. dkemme
    dkemme Supporting Member
    Greeley, CO
    Here they are!
  20. nativewolf
    nativewolf Member
    viena va United States
    What kind of dirt do the penguins have on Musk?
