Electroman
Banned
We should do this for all future Starship missions.@Electroman and I chatting on the Discord Channel about that... looks like one Raptor out on ascent and a diff one on splashdown
Who said that one tile lose means lose of the ship? ; P
Stainless steel is the real space craft material. I bet if you drop Cybertruck from space it's still drivable but looks like Ship's forward flaps...
Did the flip happen too late and too close to the ground? Did the engine light up too close to the ground? Did it even light up?
I'd be there.I'll try and set up ahead of time for IFT-5.... it occurred to me last minute. Thanks for hanging out...
They had a good relight and flip, slowed to 2 km/h, then apparently cut the engines and dropped into the water. The engine telemetry was out, and the tank telemetry was useless because the vehicle doesn't use the main tanks for the landing.Did the flip happen too late and too close to the ground? Did the engine light up too close to the ground? Did it even light up?
What I don't quite understand, they had two cameras in the ship and we did see two different views. But in the later part of the mission, only one that was close to the forward flag was used. And even when that one got covered in debris during the final parts of the landing, they never used the other camera... unless that one got destroyed much earlier
Abso-****ing-lutely. Incredible that one flap (and maybe others) could appear to have been seriously damaged yet continue to function, and that the flip worked and a soft landing was achieved, and that it maintained telemetry and video through a cracked and damaged lens! “Epic” doesn’t begin to describe it.They had a good relight and flip, slowed to 2 km/h, then apparently cut the engines and dropped into the water. The engine telemetry was out, and the tank telemetry was useless because the vehicle doesn't use the main tanks for the landing.
The only word I have for that entry, descent and landing is "epic". What a beast of a machine. What amazing communications.
On edit: @TunaBug agreed! It's The Little (big?) Flap That Could...
Not to mention a network for the feed so that they don't have to hunt down a black box. Will BO be able to do that?
It's not clear what combination of things has to be in place. It may be that there is a huge communication window above any reentering vehicle, and the only thing that was ever needed for continuous communications was having some satellites to talk to. On the other hand, it may be that SpaceX was barely able to pull it off only because of the size of the vehicle, the number of satellites available, and their low altitude. On the third hand, the combination of Amazon's Kuiper and Blue Origin's Jarvis might produce an even better outcome. Time will tell.Will BO be able to do that?
