IFT-5 in about a month:
I wish he had been clearer on what “strong” meant in that context. Stronger attachment points? Stronger tile material? Both? Do the new tiles weigh more? And how are they going to attach the new ablative pieces?Also from that stream, Elon said they will put an ablative secondary structure underneath the tiles just in case tiles fall off, and they have new tiles that are twice as strong all for the next ship.
More details will beget more questions.I wish he had been clearer on what “strong” meant in that context. Stronger attachment points? Stronger tile material? Both? Do the new tiles weigh more? And how are they going to attach the new ablative pieces?
They should not have put the tiles in until IFT4 mission was complete.
But they do know that reentry survival and tiles performance is THE unknown and the main focus for IFT4.Easy to say in retrospect... but at the same time if they operated in such a sequential manner with everything, we probably wouldn't be where we are today...
But they do know that reentry survival and tiles performance is THE unknown for IFT4.
So why not wait till the test is completed before loading up on the tiles?
Ship 30 was stacked in August 2023. Many moons ago.The ablative underlayment option was conceived/developed after the ship was tiled
Slackers. !
As with all things Elon, it's a package deal; crazy rants online combined with crazy ambitious plans for the future.
From this NSF video, don’t recall seeing this kind of damage after the first four test flights.
My expectation is that the rails will be raised long before the booster approaches. They'll leave the left arm static, bring the booster down and "lean against" it. As the booster is moving to lean against the left arm, they'll close the right arm on the booster and throttle down, allowing the lift pins to settle on the rails.He does not think the booster will fully null out its vertical velocity and fully hover because it will be very hard to keep the booster truly vertical as the chopsticks come in and the landing rails move to the correct position to engage with the booster pins.
Number three. The goal is to eliminate variables of motion. If the booster is against the left arm, then the left arm doesn't need to move, and the booster gets a bit of stabilization from that arm. At the same time, the target position for the right arm would be known precisely.When you say "lean against", are you speculating that:
