I recently had a car charger installed in my garage for Model 3.
6 guage cooper wire (6/3) running from panel in the basement to garage to feed the Charge point charger
The electrician drilled a hole in the concrete of the basement to run the wire through.
Today, I was filling in some gaps in my garage after garage door And window installation using spray foam.
I decided to use some of it to seal the area in the garage where the electrician fed the wire through the concrete.
I might have overdone it. Should I be worried and remove the spray foam? If so, how do I do it? It's been more than 12 hours and cured I guess.
My M3 charges at 40 amps btw
