I'm not trying to complain about driving fast and getting lower than expected range. I've been reading that the range estimate is off, so to use percentage as well. But I'm legitimately curious how this works.
I've attached shots of both range and percentage and they don't add up.
I started at 90% with 216 miles of range. According to screenshots i am now at 47% with 112 remaining.
Used during this period are 19kwh and 88 miles of driving.
At 211Wh/mile, i should be well above the EPA economy estimate. Why am i consistently getting less than the advertised range?
View attachment 403467 View attachment 403466
There is clearly a discrepancy, but it is nothing unusual or unexpected.
How long since you charged?
If we assume that the battery is 55kWh to give a rated range of 240 rated miles at 100%....that gives us a 230Wh/rmi constant (this may not be exactly correct but let's go with it...)
You used 216-112 = 104 rated miles.
104rmi *230Wh/rmi = 24kWh.
The meter in the car only displays energy used while you are in DRIVE. If you are in park, or if you are parked overnight, it does not count AC/heat/vampire drain. They are not included in this number.
The meter displays 19kWh used. There are a couple possible reasons for this:
1) The meter is just a meter, it may read a few % low (but not 19/24, 20% low).
2) You parked the car for a significant amount of time (you should expect to lose 3-4 rated miles a day (Tesla's number and NO ONE gets significantly lower than this on average in spite of what they may say here at TMC...), and MUCH more in some other cases: can be greater than 20 rated miles per day if you are using Sentry mode, cabin overheat protection, 3rd party apps that are misconfigured and don't let the car sleep, etc.
Feel free to do a test where you do nothing but drive the car after a charge and do the appropriate before and after calculations. You'll find that the meter in the car and your rated mile usage will line up better (you may find that there is a few % discrepancy still).
For true range, all that matters is how far you can go on a single charge without stopping so from that perspective this stuff does not matter much, but it is good to be aware of these other factors, which can be significant and add to your budgeted (small) charging costs - and could catch you by surprise if you expect the car to not lose energy when parked - it is always leaking energy while parked.
Your true achievable range in the SR+ looks to be about 255 miles, with a driving style & average speed matching the one you pictured, which is pretty awesome. But you will never get this if you spread out that driving over multiple days.
