I'm starting a new thread since this is really about driving in pretty extreme conditions
Car is a new Model X P100DL with 22" wheels.
Lastnight a friend and I went on a 300 mile road trip at -20 degrees Fahrenheit to deliberately see two things:
1. Is it possible to stay comfortable without "wrapping up in a blanket"?
2. Just how much battery power will we use?
The trip was Bozeman, MT supercharger to Billings, MT supercharger. On the way down temps ranged from -9 to a low of -23, the average was about -14 overall. We left Bozeman at 96% charge with a rated range of 270 miles. 140 actual miles to the Billings supercharger, thus leaving me 130 rated miles of margin. For reference Bozeman is 4800' elevation and Billings is 3100' with 2 substantial mountain passes in between.
The entire trip we both used our seat heaters set on 1, I turned the steering wheel heat off and on throughout to maintain comfort. (REALLY wish the wheel had a high and low and there was a much easier way to turn it off and on, having to go thru a couple pages on the touch screen is just plain silly)
Driving speed was 75mph with some areas slowing to 60-65 due to road conditions. Very little wind. On the way down I had cabin heat set to 78, outside air and fan speed set to 9. (Any higher fan speed forces recirculation and instantly fogs the windows). My buddy and I were both wearing jackets, but otherwise not dressed for winter, so to speak. We were both mostly comfortable, but our legs were on the cold side, my left leg especially cold along the driver's door, to the point I was uncomfortable. So my initial thoughts were if I had brought a blanket to lay across my legs, I would have been completely comfortable, my buddy agreed. Conclusion, having to use a blanket in a $120,000+ car shouldn't be necessary, but given the fact that 20 below is pretty extreme conditions, it's certainly not the end of the world and acceptable. I have driven in even colder conditions in numerous ICE vehicles and not even needed my jacket for reference. So the conclusion is the heater is barely adequate at best, but at least it's "doable" to drive in the cold.
When I arrived I had 21 rated miles left, so I used 249 rated miles to drive 140 actual miles, average was 584 wh/mi. You'd better have PLENTY of excess range stored up before setting out in these conditions.
Now the return trip...
Charged to 95%, 267 rated miles range.
Temps were more consistently in the -20 range, with a low of -27. I'd say the average was pretty much -20. Heater set to the same level. We were both uncomfortable, our legs were cold, so that little bit of difference was definitely the breaking point and had surpassed the limits of the heater. Well at least now I know. Then I got the idea to install the sun shade on the upper half of the windshield. What a difference!!!! It hangs down maybe an inch or so from the glass creating just enough air space for an insulating pocket. Holding our hands a few inches below the glass before we could definitely feel very cold air dropping from the glass and landing right on our legs. After the sun shade we couldn't feel the cold air. 20 miles later our legs were warm and we were both completely comfortable. Great! However, about 40 miles in to the trip I started getting the slow down messages, decided there is no way to make Bozeman unless we either drastically slow down, or lower the temp back to the uncomfortable range. Stopped at the Big Timber supercharger 60 miles from Bozeman instead. Drove only 80 miles, used 165 rated miles. 698 wh/hr. Climbing definitely was hurting us. Arrived back home safe and sound in Belgrade with an average usage for the trip at 630 wh/hr.
So overall what I learned is the sun shield makes a HUGE difference (I have the evanex insulation panel I'm going to install between the window and sunshield and try again tonight) and you'd better have at least twice your actual distance in rated range available to make it. My car is a 90D with 20" wheels once I receive it, so my actual driving distance is probably pretty close to the P100D with 22's, if not slightly better.
Again, the point of this wasn't to see "how far we could go if we have to" it was to see how the car would work in very cold conditions without making any sacrifices to comfort or speed. Obviously I know if I had slowed down, wrapped up in blanket and put on gloves and a hat I could have driven substantially further, but I didn't buy a $120,000 car to not be completely comfortable driving it the way I want. =)
Oh, I want to add for the last 10 miles of the trip I jumped in the middle row of this 7 seater. Very comfortable temperature wise, but the right side of my face so close to the window would have probably started to get uncomfortable after several more miles. The 6 seater, which is what I ordered seems to have the outer seats set closer to the middle, I didn't remember my shoulders actually being against the door when I set in the back of the showroom 6 seater, I hope this is the case.
The rear heater is a joke, we turned it up 80 degrees and turned the fan speed down to 3 so it wasn't blowing too hard, the air coming from the vents was Luke warm at best, I'd estimate 70 degrees or so. Any higher fan speeds and the volume of air actually made it colder. Fortunately in the middle row I was very comfortable just from the front heater. Not sure what the 3rd row would be like.
So there you have it, cheers! =)
