Sudden Unintended Acceleration
ken830
Model S 85, Model 3 Performance
Jun 19, 2012
1,108
362
San Carlos, CA
Pedals move with AP. Always be vigilant. You are in charge, don't blame software for user error.
I will re-check my assumption on this. I just haven't noticed this for the accelerator before. I do notice it for the brake pedal because my foot is always over the brake pedal when in cruise/AP.
wk057
Senior Tinkerer
Feb 23, 2014
5,651
11,368
Hickory, NC, USA
I've no doubt the accelerator pedal and the hardware is solid, but the car is eventually commanded to accelerate by software. This is evident because there is no physical movement of the pedal when accelerating under cruise control, autopilot, and summon.
How can we independently audit the software path? There is more complexity in software than hardware and I expect more room for unintended behavior.
I was always in the camp of "it's always pedal misapplication" but a few months ago, my father also claimed unintended acceleration (close, but no collision) in his Model 3 and the car had some strange software behavior immediately afterward (unable to lock vehicle). I guessed it was unintended activation of cruise control (default to speed limit), but Tesla came back with 100% accelerator pedal position for 1 sec.
Now I'm left with wondering how granular is Tesla's logging and does it log each of the raw pedal position channels or just the final interpreted position? That makes a huge difference in how believable the logs are at capturing the physical position of the pedals. Have you actually seen what the logs log? And at what frequency?
Knowing this would definitely help me settle it in my own mind. In the mean time, I'm a bit more cautious and hyper-aware of my own foot position when pulling up to my daughter's elementary school in the mornings.
Tesla's logging is ridiculously thorough. Last I saw they were logging changes in both tracks of the accelerator position at up to 100Hz while the vehicle is in gear. Same with the brake pedal switch (also dual and redundant).
As for the software, all of the autonomous functions have interlocks that prevent usage at high torque command. You're not going to see a car summon at more than a couple feet per second because this is limited and crosschecked by multiple pieces of hardware. Cruise control has a defined max rate of increase in speed which is crosschecked in multiple places as well. Full acceleration by any autonomous feature is not possible.
The autonomous functions never show in logs as a pedal application, either. While cruising or summoning, if your foot is off the pedal the logged position is 0. If the logs say the pedal was pressed you can rest assured that the pedal is pressed.
Also, internally, the pedal position is measured thousands of times per second. It won't accept an instantaneous change from 0 to 100% without intermediate increases in position matching real world usage. Even if you do the fastest kung fu speed kick at the pedal from 0 to 100% the hardware will get multiple data points in between as it changes from 0 to 100% and can know for certain that it was indeed a physical pedal press.
As noted, I've actually been working to achieve a software-based control over acceleration for a while now. I literally want to launch my S down a drag strip via remote. Making this possible has been extremely difficult due to all of the safety crosschecks Tesla has put in place for throttle control. Seriously, I'm putting considerable effort into a hardware/software solution to try and get the car to do basically a full acceleration without a human pressing the pedal. There are so many safety interlocks to defeat, both hardware and software wise, that I've benched the project multiple times in frustration. I only recently managed to achieve some limited success with the project. I can assure you and everyone else that this is one area where Tesla really did their due diligence to make their control system safe and reliable. Kudos.
Edit: Also will note, the accelerator pedal can not be commanded to physically move. Unlike the brake pedal, there is no physical connection to anything that can be commanded to move. It's just a sensor.
If you look at my post history, you'll see I'm the last one to give Tesla a pass on something and probably the last person to defend Tesla on anything at all without a solid basis for doing so.
This one really just needs to be put to rest. But, humans will human it seems. On a broader view, our culture has definitely been moving away from people accepting personal responsibility for themselves and their actions (or inactions) and more towards baseless finger pointing, and passing the buck, and an overall "gimme gimme gimme but I'm not going to work for it, I can do no wrong, and it's always someone else's fault" type of attitude. It's depressing and makes me fear for upcoming generations.
Accept responsibility for your actions, and move on.
ken830
Jun 19, 2012
1,108
362
San Carlos, CA
Thanks for this comment. As long as they are logging both of the raw channels of the pedal position then I feel better. I wish the could provide more details and a snapshot of the the actual logs. And in my mind, I will have to accept that my dad just mistaken the pedal, which is where I started.
Jason, I have been following you closely (here, on Twitter, HSR Motors, Youtube, etc) since you came to the scene years ago and I highly respect your opinions and admire (and am amazed by) your work. This is the reason I wanted to ask you about the logging and software.
Reactions: alloverx
Silicon Desert
3,031
2,790
Sparks Nevada / GF 1
However... you can have uneven pressure applied between the two pedals and the greatest pressure point will react. Yes with the Tesla you will get a dash warning but that could be the least of what you are paying attention to when you are scrambling from making the mistake.
Well that might be the case on a FEW ICE vehicles, but not on a Tesla. Slightly apply the brake, and press the accelerator all the way to the floor. Car goes nowhere.
Reactions: Maximapolak
fren
104
24
france
QUOTE]
hi wk,
so basically i understand than the pedal accelerator does not move by itself
but
i always had the impressions it did, do you think it's because maybe i activate taac/ap at a speed lvl , so the pedal is at position and few minutes later , speed has changed and if i try to feel where is the pedal , it seems not at the position it was before
just a question of feeling from my foot ?
i never checked the brake pedal , but seems it s always not moving , always at same place
i don't think our EU models( french one for me ) are different than US models
regards,
kengchang
2,145
12,734
hi wk,
but
regards,
Tried it this mornings, when you enable AP the accelerattor slowly returns to neutral position and does not move afterward. Brake does move with the current car action.
malcolm
3,072
1,729
Can some kind moderator copy @wk057 's posts to a separate wiki or some sort of Hacker's Insights sub-forum?. Really valuable info which get lost in the these threads and not everyone knows how to search for a forum member.
Cheers
Reactions: wk057 and Dr. J
DarkMatter
1,126
870
Olympia, WA
I'm pretty sure only drive by cable cars move the pedal for cruise control. Never seen a drive by wire car that does it.
MP3Mike
14,978
31,851
Oregon
@wk057 Are you up for a good laugh?
Really? The car rammed the wall, backed up, rammed the wall, and then parked in the neighbors driveway? And the airbags went off? When? On first impact? Doesn't that disable the car?
Wow, just WOW!
mhan00
1,053
1,268
Southern California
Wow, Tesla is making major progress with their AP if it’s capable of changing gears and then parking in their neighbor’s driveway. Was it an adjacent neighbor, or the person across the street? Lmao.
S4WRXTTCS
5,315
5,957
Snohomish, WA
Smart Summon doesn't move fast enough to cause the airbag to go off. And once the air bag goes off the HV battery is disconnected. The story as stated just isn't possible.
Guess my attempt at humor failed.
As to the story its so completely ridiculous that there isn't any point in any having a serious convo about it. Like you said it simply isn't possible.
Reactions: croman and MP3Mike
whitex
6,379
7,545
Seattle area, WA
Wow, just WOW!
LOL, Model 3's price range allows for much larger sales volumes, therefore many more chances you'll hit on a creative customer who believes nothing is ever their fault. The way Elon markets auto-pilot, you might actually be able to convince 12 jurors the car did that - just have to keep any pragmatics off the jury.
PS> maybe Tesla needs cameras on the driver and the pedals, to quickly dismiss such complaints. Footage should be saved around the airbag deployment of course.
