Sunroof leaks...?
Discussion in 'Model S: Interior & Exterior' started by SabrToothSqrl, Jun 5, 2015.
  1. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    Found this today.... Not really a happy camper... Goes in the 24th...
  2. Sosius
    Sosius a.k.a. Uptown Frunk
    Gulf Coast
    In my extended family, we have Toyotas (2), Jaguar (2), and Lexus (1), all with sunroofs. All of them leak, especially when the drain channels are clogged.
  3. InternetDude
    InternetDude Member
    SK/Canada
    I've owned two vehicles in the past with sunroofs, they both had problems. I opted for the lighter, cheaper, less problematic solid roof ;)
  4. supratachophobia
    supratachophobia Active Member
    Columbus, Ohio
    Long story short, welcome to the club. Were you parked at a downward sloping angle? And what is your last five of Vin? That will help figure out which leaky sunroof you have.
    Bottom line, This shouldn't happen, SC can fix.
  5. SabrToothSqrl
    PA
    It's. A 2013, always parked level and inside at home and work. I'll have to find the VIN.
    can I safely assume the SC will replace the now stained part?
  6. Frank Mucus
    Frank Mucus Member
    It's a secret society, all we axe is trust.
    You just have some bad cars then.
    I've never had leaks from any of my other cars with a sunroof. I've had the mechanism not function in one, but that was the extent of it.
  7. jcaspar
    jcaspar Member
    Sacramento
    Maybe you never owned a Toyota...
  8. 1208
    1208 Active Member
    UK
    #8 1208, Jun 6, 2015
    Volvo 440 sunroof never leaked. In rainy England.
  9. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    I've never had a leak in eight cars.
  10. SabrToothSqrl
    PA
    The one in my 2009 Tahoe does not leak. Nor does the one in my 2005 Tribute.
    Technically all all sunroofs leak water, it's where that water goes, that's the issue. Drain may be clogged, but still, warranty.
  11. Alipapa
    Alipapa Member
    Hong Kong
    i have never had a leak in my previous cars. (Japanese, German, Italian)
    and i have gone back to service center 3 times for my model s glass roof. ( 2x water leakage, 1x for not being able to open)
  12. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    Ditto. Never had a sun roof leak on any previous cars. That includes Acura, Toyota, and Volkswagen. Also no leaks in my Model S.
  13. Sosius
    Gulf Coast
    I park my cars under oak trees and crepe myrtles, which produce large amounts of pollen and detritus from flowers, respectively. The fust from the trees eventually gets into the channels and the drain holes, causing a backup. This situation is not helped by the fact that we get over 5 feet of rain a year.
