MGM-S75
Just drove by and the cones are still there with the same signs “no parking on 7/8/21 between 12am-4:30am” :/
I'm wondering if they meant 7/18 this is such a tease I can’t take it anymore
Anybody visited recently?please share update
A supercharger site isn't actually able to provide 250kW to every stall simultaneously. Each V3 supercharger cabinet (attached to four stalls) can draw up to 350 kVA continuous from the grid and 575 kW from the shared DC bus (this allows power to be routed between cabinets and to/from a megapack), according to its nameplate: Pictures of V3 Supercharger cabinets For four cabinets, the max continuous draw from the grid would be 350 kVA * 4 = 1400 kVA or approximately 1.4 MW, within the capacity of 2500A switchgear.2500 Amp, 277/480V. Does this mean the input power supply is 480V, 3 phase?
e.g. 480V * 3 * 2500A = 3.6 MW.
3.6 MW / 250 kW (per stall) = 14.4 stalls max.
Doesn't this location have 16 stalls?
Please correct my math if it's wrong. At a popular site like this. I expect it will be > 50% stalls in use most of the time. If so, almost nobody will ever see the 250 kW peak in our cars. Unless we're lucky and charging late nights when there's extra power capacity (empty stalls)
Also, it's true that if you have a bunch of cars show up at once, all with nearly empty batteries, under ideal circumstances, you won't get the 250kW you might otherwise expect. But that's unlikely to happen, assuming cars arrive independently and at random.
480V * 1.73 * 2500A roughly equates to a 2000kVA transformer. SCE usually has a boilerplate on their transformers that lists the power and voltages, so you could look for that.e.g. 480V * 3 * 2500A = 3.6 MW.
We've been told that 250 kW v3 supercharger stalls don't share power. I guess it isn't true!
Assuming just 1 cabinet with 4 outputs, and 4 thirsty cars, each car would get only 350kW / 4 = 87.5 kW!
If there's extra 2 "free cabinets" available to provide aux DC power, then it would be 350 kW + 575 kW = 950 kW /4 = 237.5 kW per car.
At a site like this with only 4 cabinets and no on-site battery storage, then we can expect to never get the full 250 kW to the car if more than 6 cars charging concurrently. e.g., the site is 50% full.
350 kW * 4 cabinets / 6 stalls in use = 233 kW per stall.
