General AC / DC info:
- Supply from the grid is AC
- Supply from battery storage or solar is DC
- Cabinets are connected to each other via DC
Specs of the units:
- The line "AC input - Maximum continuous power" where it says 350 kVA, means the grid connection *per cabinet* is approx 350 kW. Note there are some losses, but peak power can also slightly exceed this, so I'll use 350 kW as an approximation.
- The line "DC input / output" where it says 575 kW means that each cabinet can accept 575 kW from DC sources, whether that be solar, battery, or other cabinets, and can also supply the same to other cabinets.
Examples - these are based on the specs above. If my understanding/assumptions are wrong the examples will be wrong - please let me know if that's the case!
- A 1 cabinet site with no solar or battery has no DC supply, so the 350 kW is split between the three stalls (average of 116 kW each). For four stalls it would be an average of 88 kW each. I guess that's why there aren't that many of them.
- A 2 cabinet site with no solar or battery can only supply 350 kW between cabinets because that's all the 2nd cabinet grid connection can provide. So if all four stalls are packed (and the other cabinet's stalls are empty) that's an average of 175 kW each. For a three stall per cabinet site, it's 233 kW.
- A 3 cabinet site with no solar or battery means one high demand cabinet (and the other two being empty) can get 350 kW from the grid and the full 575 kW from the other two cabinets (average ~287.5 kW from each cabinet). So that's 925 kW total (average of 308 kW for 3 stalls-per-cabinet, or 231 kW for 4 stalls-per-cabinet).
Note in all cases, the average being lower than 250 kW doesn't affect the peak speed of individual stalls, and in many cases wouldn't be noticeable by the driver. The average numbers would only matter in practice if you had multiple Model 3 LR/Performances, all at about 5-10%, all with their battery pre-heated, all arriving at the same time, and all going to stalls connected to the same SC cabinet.
I mention 308 kW above, which is of course more than what the stalls will supply, but I don't know if the current limitation of 250 kW is the car or the stall. Maybe the existing hardware, without any changes, will be able to charge a S/X Plaid, Cybertruck or Roadster at greater than 250 kW?
