Blu Zap
Grinning member
We will be going North through Corning this Thursday, 6/20/19. I am hoping the traffic bottleneck is only on weekends for now. I know this is the I-5 chokepoint for SuperCharging.
Full house on Saturday 06/16 at 1 PM, with up to five cars waiting. (#2B was out of order).
Hey there! As of tonight Chico is reported as up an running! Hopefully it eases the burden on corning!We will be going North through Corning this Thursday, 6/20/19. I am hoping the traffic bottleneck is only on weekends for now. I know this is the I-5 chokepoint for SuperCharging.
Edit: Called Tesla, they are aware of the problem.
We charged there last Thursday, 6/20/19. All good. Two other Teslas. Faster than usual charging rate. Perhaps from the new software update. This temporary Urban charger set up was on the other side of the transformers from the permanent chargers. Have not seen 3 chargers on one platforn. Kinda' hard to get three Teslas in there at all let alone blocking each other.
It’s a layout that can accommodate numerous setup scenarios@McManX thanks for clarifying. Weird set up.
Second in line here right now. Nav showed 4 available when were 5 minutes away so either everyone just arrived or the nav was wrong. Anyone’s guess.
Also: 2B is still out of service.
Also #2: I wound up in one of the 72kW "urban" stalls and I'm unable to draw more than 57kW. 90 minutes of Corning, coming up!
30 minutes of waiting followed by an hour and 20 minutes of charging thanks to my need for 100% to get to Vacaville. And in the end, that wasn't enough. I had to drop the trailer 4 miles from the Vacaville Supercharger because I was down to 10 miles of range and that was far too close for me. My 90D battery has degraded to the point that the Corning-Vacaville stretch isn't comfortably passable with my camper. It was always tight, but the next time I tackle that stretch I hope to have a newer X with more range. We'll see.Hope you got on your way reasonably quickly.
Corning definitely needs an expansion, though. And my history there gives me the impression that they have power issues as well - I have often run into situations where I get reduced rates of charge, even if I'm alone. I used to blame the heat but I'm starting to think it might be something with the location.
This was a consideration, but I was already facing an 11 hour day of driving with the full family. I also had some concerns about reaching Chico from Shasta, since it's 132 miles (though it would likely be fine with the 3000+ ft descent). In the end, it may have taken about the same amount of time anyway.While SR99 out of Red Bluff is slightly longer and slower, charging at Chico for 20 minutes (guessing) and Yuba City for 25 minutes (again, guessing) would let you reach Vacaville without an interminable wait or rock-bottom charging rates. Besides, the drive is much nicer, and there is less traffic.
I suggest using the portable charger rather than 2A, as they should deliver a steady 72kW.Nobody was at the portable urban chargers yet though.
