I'm not sure why you are jumping to this conclusion but I think the assumption of causality is incorrect.If that's the case, then it would seem that the Idaho Springs Supercharger is just being ignored by the Navigation system.
Clear Creek County is on lockdown. They are not permitting non-residents on their roads. Perhaps they requested tesla remove the location until the order expires.If that's the case, then it would seem that the Idaho Springs Supercharger is just being ignored by the Navigation system. That seems rather odd since the Supercharger has been operational for two months now.
For those who charge in Silverthorne and heading east, I doubt navigation would ever suggest charging in Idaho Springs since it is mostly downhill from there back to the metro area. We can easily charge in Glenwood Springs and skip both Silverthorne and Idaho Springs and make it home with plenty of charge. Idaho Springs is more helpful for those heading west/uphill and who might've skipped Lakewood. You shouldn't expect the car to suggest a charge there if it isn't needed. Now that Lakewood is online, suggestions to charge in Idaho Springs will be even less common.If that's the case, then it would seem that the Idaho Springs Supercharger is just being ignored by the Navigation system. That seems rather odd since the Supercharger has been operational for two months now.
Yes, eastbound from Silverthorne is very easy, as you saw. One caveat for those headed westbound to Silverthorne: you need enough to make it to the tunnel, as opposed to just focusing on the energy projected for arrival at Silverthorne. In our mountains, first you have to make it over the pass before regening your way back down to the Supercharger Station. Eastbound over Monarch Pass to Poncha Springs is much the same.Silverthorne is about 9,000' and Idaho Springs is about 7,500', so I had a 1,500' drop working for me along with low air density. If I had kept the speed down, I think the car would have made the 34 miles between the two cities while using zero battery charge.
Outside of Colorado, this is going to be pretty rare, but I have run into this phenomenon on a couple of occasions and I can confirm that the Nav does not account for going over a summit prior to a steep drop to a supercharger.Yes, eastbound from Silverthorne is very easy, as you saw. One caveat for those headed westbound to Silverthorne: you need enough to make it to the tunnel, as opposed to just focusing on the energy projected for arrival at Silverthorne. In our mountains, first you have to make it over the pass before regening your way back down to the Supercharger Station. Eastbound over Monarch Pass to Poncha Springs is much the same.
So, don't try to cut it too close! Here's a plot from Denver Supercharger Station to Silverthorne, back when the Denver airport station was pretty much the only Supercharging option along I-70:
^ Needless to say, I charged a bit longer to have more of a buffer.
^ Elevation Profile from Denver to Silverthorne
^ Energy plot from the Ridgway area (Ouray County) to Poncha Springs Supercharger Station, over Monarch Pass. I made it without difficulty because of the reduced drag at high altitude, which acts as something of an energy bonus when driving in the mountains. [My car is a short-range S-60 — currently about 179 rated miles of range at 100% — so these trips can be difficult even though they would be easy in almost any other Tesla model.]
^ Elevation plot from Grand Junction Supercharger Station, over Monarch Pass, to Poncha Springs Supercharger Station.
Mostly I was just surprised that when I told it to specifically navigate to the Idaho Springs Supercharger, it wouldn't do it. I wanted to try one of the 250kW chargers to see how it would work.For those who charge in Silverthorne and heading east, I doubt navigation would ever suggest charging in Idaho Springs since it is mostly downhill from there back to the metro area. We can easily charge in Glenwood Springs and skip both Silverthorne and Idaho Springs and make it home with plenty of charge. Idaho Springs is more helpful for those heading west/uphill and who might've skipped Lakewood. You shouldn't expect the car to suggest a charge there if it isn't needed. Now that Lakewood is online, suggestions to charge in Idaho Springs will be even less common.
I just went out to the car and had it navigate to Cowdrey (north of Walden) from my place and it suggested I charge in Idaho Springs...so it will definitely still suggest that Supercharger if it is needed for the trip.
Ah. I don't think we realized you were only having the problem when trying to do it with voice. I tried by voice and confirmed it isn't working for me either. It does work when I select it on the map or select a destination which would require me to charge there.Mostly I was just surprised that when I told it to specifically navigate to the Idaho Springs Supercharger, it wouldn't do it. I wanted to try one of the 250kW chargers to see how it would work.
I checked after I got home and the Idaho Springs Supercharger does show up on the map, and if I tap the marker, it will navigate to it. It just won't do it with the voice "Navigate to" command. And yes, I did try the void command from home as well.
I'd be a little more excited if there was actually a SuperCharger there.There's a Lakewood in central NJ about half way between NYC and Phila.
https://www.clearcreekcounty.us/Doc...2/2020-02-Board-of-Health-Public-Health-Order
This is a bummer. I had been looking forward to making that drive this summer as it has probably been 25 years since I've been up there.For anyone reading this thread, you may be interested to know that the Mt. Evans road will be closed to cars this year. Still open to hikers and bicycles, but no services (eg., restrooms) will be open.
Popular scenic Mount Evans Highway will stay closed to motorists for all of 2020
Look at the bright side. They will be free to do repairs and repaving this summer, so the road should be in good shape next summer.This is a bummer. I had been looking forward to making that drive this summer as it has probably been 25 years since I've been up there.
